First thing I did after installing my B & M blower was put in a cage then ladder bars. I already had SD rods and a four bolt main....I shifted at only 5,200 rpm. No aftermarket block available at the time but I wasn’t close to maxing out a Pontiac block. When I bought my 8-71 then I bought a IA block. Going fast safety is not cheap.
GTO George |
FYI, I bought my is block because I broke my factory Pontiac block when I pushed HP near 800, luckily I only broke my frank and nothing else!
GTO George Last edited by GTOGEORGE; 08-31-2018 at 12:15 PM. |
Your other alternative is to build a throw-away boosted engine.
Just make sure the rings and bearings are good, arp bolts in the rods, basic balance job. Then install the turbo stuff and go beat on it on the street. If it blows up, build another CHEAP engine. Learn about Boost and Tuning with a carb and have FUN. Save your money for the good stuff down the road. This is if it is a true street car with boost like 70bird has. There is a sharp guy with boost on a street car. (Much like Charlie66) with his deal, having fun! Tom V.
No Carb here - I used to run a 850 Holley DP, but now I run the FiTech Fuel Injection. It is the 1200 hp power adder system so it will take it all day. Technically my current engine is a cheapy - other than the top end. I bought it for $1200 fresh rebuild with the arp rod bolts and TRW's. Just dont want to mess up the top end if things get bad. lol
1980 Trans Am - Street/Strip 462 Best: 7.08@95 with 1.49 60' in the 1/8th. 11.17@119.8 in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas. Admin of Pure Pontiac Powered Outlaws on Facebook. |
Odds of hurting the top end, with the pieces you describe, is minimal if you have stainless one piece valves in the heads. Higher pressure springs help on Boosted engines too with the boost applying force on the 2.11" intake valves vs NA pressures.
Is the camshaft a flat tappet or Roller? Tom V.
It does have Ferrea Valves. Has comp 914 springs - Right at 160 lbs seat pressure before break in. It's got a 236/242 Hydraulic Roller, 600/620 lift on a 110 LSA
It also has a good ignition system. MSD 6AL-2 Box with a MSD Pro Billet distributor. I currently have the rev limiter set to 5800 rpm, and I shift at 5500
I run 250 on the seat but i have a solid roller. When you add boost you need a little more seat pressure. There is a formula for it. I do not have it handy.
Here is a example that would get you close"
If the I.D. at the valve seat is 2.11" and the valve stem diameter is 5/16", the area of the valve on it's seat is about 3.5" for simple math. Multiply that by the boost pressure, 15 psi so 15 psi times 3.5 gets you 52#s more spring force on the seat (for 15 psi boost). You need to be over 210 on the seat to allow for the 15 psi boost. Tom v.
Damn, that had to hurt! Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
So 2.11 X 15 psi = 31.65 + N/A roll cam seat pressure 225 = 256.65 seat pressure. Is this a good way as well Tom? I hope so.. lol
My Half AN Injun..... |
Your calculation Charlie is exactly correct just we said it different ways.
And Because you posted your calculation in a line form might be a bit easier to understand. You are just using the Diameter of the Valve and I was using the AREA of the Valve Seat Diameter (under the valve) but close enough. Tom V.
