Bob-Explain why the crud never seems to be on the backsides of the exhaust valves.
http://www.machdevelopment.com/album...775/527566.htm |
Bruce, as exhaust gases flow past the valve guide area,a low pressure area is created, causing oil to pass through the valve guide and into the exhaust.
There is no such thing as too much cam, just not enough engine. 1966 GTO - 11.31@119 (3478 lbs) in 1979 1967 Firebird - 9.73@138 (2940 lbs) in 1986 400 cu in / 295-298 cfm RAIV / Lunati Cam 278/283 - .704 lift/5.13 gears |
[ March 31, 2002: Message edited by: Bob Eiler ]</p>
The guy that did the heads on my son,s Tempest turned the guid boss down and installed Chevy seals. I have not had the valves out, so I can't tell anyone if it works or not.
Bob ,have you ever used Chevy seals?
www.pontiacfever.freehomepage.com |
