Old 01-14-2019, 02:55 PM
gman005's Avatar
gman005 gman005 is offline
Get some Viking shocks it will help out.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 01-14-2019, 08:51 PM
Half-Inch Stud's Avatar
@GV455; what kind of afco rear shocks are 1/3rd the $377 price?
@gman005; are Viking rear shocks affordable, like under $125/pair?
@JSPONT; are QA1 rear shocks like under $125/pr?
Hey how about a pair of affordable rear shocks that HELP 60 foot over "replacement shocks"??????
Old 01-14-2019, 11:14 PM
73 TRANSAM 73 TRANSAM is offline
The Viking crusaders are around 300 a pair shipped from Vikings. Get the AM valving from the get go. Get the front first then the rear when the budget allows. JS Pontiac is the 10.88 run on the track? I think you need to run some real slicks as your car is making some serious power. Good luck. I'm sure my car will be like yours when I get it out this summer.
Old 01-14-2019, 11:22 PM
Mike Davis's Avatar
Agree X2!
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-15-2019, 03:07 AM
Stan Weiss's Avatar
Just a WAG.
60 Foot ET = 2.1015
330 Foot ET = 5.1261
1/8 Mile ET = 7.3609
1/8 Mile MPH = 111.5172
1000 Foot ET = 9.2733
1/4 Mile ET = 10.8848
1/4 Mile MPH = 140.8490
60 Foot ET = 1.6013
330 Foot ET = 4.2404
1/8 Mile ET = 6.4133
1/8 Mile MPH = 113.5469
1000 Foot ET = 8.3007
1/4 Mile ET = 9.8965
1/4 Mile MPH = 142.0448
Stan
Pontiac Pump Gas List
Old 01-15-2019, 08:18 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Street, I am a street guy, I need it to hook better on the street. At the track I am pretty sure it will hook. I will find out this spring (if my health issue lets me)
It drive me crazy to see some some guys faster than me hook with stock suspensions. Nothing fancy.
I did not do a good burnout either and it was 27 degrees on an unprepped road.
The car is making power, on the the street the torque hurts me. If I every did it over, I would have done a shorter stroke for a turbo street car to loose some torque.
Old 01-15-2019, 09:53 AM
Thanks, I hope your health gets better. Good luck with both.
Old 01-15-2019, 10:43 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
To get it to hook on a street aurface you will probably be better off investing in a boost controller. Ease the boost. Also...go with a bias ply soft side wall tire. Drag radials do not recover from spinning nearly as well as a soft side wall tire. Ive tried many options in my street race days.
Old 01-15-2019, 11:07 AM
JSPONT's Avatar
I try and leave on 5 psi, that is on a M/T 28x10.5 slick. I"ll figure it out, it sucks it's so cold out now. Spring fever!
Old 01-15-2019, 11:09 AM
JSPONT's Avatar
Thanks! The health thing bums me out. I am only 50, prostate cancer they think. I have a biopsy next week. I sure hope it is something else.
Old 01-15-2019, 12:10 PM
Hooter's Avatar
Hooter Hooter is offline
My wife's a nurse and has always said that's the most treatable kind. Keep your chin up man. You got this.
67 Bonneville ragtop
Old 01-15-2019, 01:21 PM
With the spohn adjustable upper arms, maybe they need adjusted to hook?
The stock type is very bad for any kind of traction usually.
(made for comfort and softness originally)
It would be best to have the suspension scaled.
Interesting link for some ideas:
Shope Calculators
Old 01-15-2019, 01:55 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Good luck! Keep a good outlook and stay positive.
Old 01-15-2019, 02:14 PM
JSPONT's Avatar
Thanks for the words of encouragement. My best friend just went thru it. He is fine now. It is just the fatigue you get makes you a little lazy. I just hope I have the energy to get the car where I want it this year
Old 01-15-2019, 02:18 PM
JSPONT's Avatar
Shope Calculators
Some add a spacer to the upper arm mount so you can move the arms up. Since the car is street driven so much, they do not want me to pre load to much. There is a line between street and race car. I got to be right on that line. I will get it, test and tune..
thanks for the link
Old 01-15-2019, 02:55 PM
cgeise's Avatar
cgeise cgeise is offline
Boost controller will help and I never saw mention of converter info ???
Old 01-15-2019, 04:10 PM
grandville455's Avatar
grandville455 grandville455 is offline
I didn't know u were trying to hook on a street road and its 27 degrees out!
That will take a lot! I agree with a boost controller, it should help , but very little hooks on a cold road like that!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
  #38
Old 01-15-2019, 04:44 PM
JSPONT's Avatar
PTC bolt together, th 400 FTI brake, it's real tight till you add boost! The converter seems to work well. I was hoping to add a controller this season. It's a real budget, blow thru set up.
  #39
Old 01-15-2019, 05:24 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Get some SANTUFF shocks it will help out.
I FIXED IT FOR YOU!
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
  #40
Old 01-15-2019, 08:39 PM
GTO Dan's Avatar
I was talking about your 60’ times.
Don’t fret, you got this! You’ll be 100% before you know it.
