Always wanted to learn how to weld... ;-) |
I did try just mocking it up first with out any cutting and it was not happening at all. I proceeded to cut out a little at a time till I got the transmission where I wanted it then started fabbing it back together. Yah, major modification might be the wrong term, major modification might be a more appropriate term for what I just went thru turning my 91 Ford van into a 4X4 Still, there is a fair amount of work to get that TKO in there And worth every bit of the effort!
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
I used seam sealer and pop rivets.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I split my tunnel up the middle and made a pie-shaped piece of steel and welded it in place. I had to make a special shifter porch to fit the widened tunnel. I wish I would have got the tranny up another 1/2" or so, but it fit pretty well.
Here is a link of my modifications http://forums.maxperformanceinc.com/...ght=tko&page=2
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
If I can get a good deal on a LGT-700, I will probably be putting my TKO up for sale. That LGT tranny is pretty sweet.
Anybody know if that TKO600 would fit in 1979 Trans Am behind a Pontiac 455? My car is a original 4spd SE W72 car so I don't want to do any cutting on it.
I have a Doug Nash/Richmond 5 speed I removed from a 79 Trans AM W72 WS6 car, the transmission fit directly in the same place as the original ST10 4 speed with no cutting or hammering, just the crossmember was slid back and used only two holes or I think a TH400 would work to use all 4 holes.
1989 Automotive Hall of Fame Inductee |
Is there anything special about the Doug Nash\Richmond 5 speed overdrive when buying one? Or pretty straightforward?
I think this is what some people run into when they don't want to face the fact that you have to hack up the floor. If your going to do it take the leap and do it. What the hell is another 1/2" When you already got it opened up? The objective really isn't how little you can cut but rather getting the right geometry from tranny back to rear end. You leave it too low and your asking for trouble, jmo.
.....and if the angles aren't right, it's a buzzmobile.
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
I had the same issue with pinion angle, I just raised my tranny another 3/8 of an inch and the car is a lot smoother above 90. The 700 is a lot higher toward the back of the trans, which does bring the trans really close to the tunnel.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
The rear Trans Mount is in the 67 GTO Turbo 400 location vs the Muncie or Turbo 350 trans mount location. With a "Roof Car" you can typically add a couple of holes in the frame area and get the right location on a earlier A-Body frame. Convertibles are harder as they have a weld on mount on the enclosed frame. When I had the frame out I split the frame mount, removed the rear section and moved it rearward, and added a section in the open middle area. This now allowed me to run a Muncie, a Turbo 350, a Turbo 400, or a Doug Nash in my 64 GTO Convertible. I don't do car shows so 99% of the people would never notice the modded trans frame mount. The driveshaft angles should be about right with the Nash trans as the overall length of the trans is the same, just the trans mount location moved on the trans. Tom Vaught
The Doug Nash has a great reputation - I looked into buying one and was advised against it my my local tranny specialist (guy in upstate SC who used to work for Richmond before they were bought out) as he said you can't get parts for them.
I'd say 1/2 the time I purchase a used "ready to run" tranny it needs work or parts. I just don't see many "richmond" five speeds for sale that are pretty reasonable on cost, etc. |
As a note, Gale Banks ran a twin turbo BB Chevy engine in a 3rd Gen Trans Am at Bonneville. The engine made around 1400 HP. They used a Doug Nash Transmission and a Overdrive add-on. The DNE trans worked fine in the car if it was shifted properly vs Power Shifted and saw High shock loads. Just saying. Tom Vaught
Tod Hoffmann 1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd 1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler 1996 Chevy K2500 ECSB 'Poopy' 2002 Honda VTX1800C 2016 Cadillac CTS Premium My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826 |
#38
Have little info on the ROD trans Sorry.
Could be identical or much different. Nash used to have a side view of the trans dimensions. Tom Vaught
