I've been using a short little 3 pound sledge to break ball joints loose for over 40 years. Hit the side of the knuckle and the taper fit lets go. Saves ball joints and torn boots. Tie rod ends, etc. as well. I never use a pickle fork, because I usually need to re-use the boot and part. Did this in industry on hundreds if not thousands of cars from 1979-2021 with zero knuckle failures. Zero.
Jeff |
![]() Quote:
Once in a while you can't swing a hammer at the joint because how the car is engineered, but most times you can reach it. A 3 lb engineers hammer is my tool of choice, ball peen hammers just don't have enough heft to them. Spindles are made of cast steel in all my encounters, I know this because you can't use mild steel welding rod to weld cast iron. I've welded steering knuckle arms after shortening them to quicken the steering on my dirt track race cars. I have no concerns of shocking a spindle to release the ball joints, or tie rod ends. As already posted, heat will always help release any rusted/corroded piece of steel in automobiles, usually not required to split ball joints, or tie rod ends. ![]() |
The Following 2 Users Say Thank You to Sirrotica For This Useful Post: | ||
Just to follow up, the air hammer did the job beautifully. With just a 3-4 second shot from the new tool, both ball joints popped right out so easily I almost couldn’t believe it. It’s like they jumped in my lap and called me Daddy, haha. Pretty remarkable. Now that the upper control arms are in, today I finally get to install the new motor.
![]() Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Vid For This Useful Post: | ||
Cheers!
The Following User Says Thank You to steve25 For This Useful Post: | ||
![]() Quote:
Here is the tool that Skip Fix is talking about, I use a homemade version with a 6 inch long 1/2" pipe, then install a 1/2" X 3 inch long bolt with a nut into the pipe. Loosening the nut lengthens the assembly which presses out the ball joint stud. Like Skip Fix said leave the nut on.
1972 GTO 468 2 Bolt Main w/Eagle rotating assy SD Ported 295 KRE D Ports 10.8 CR OF Hydraulic roller w/ 1.65 stainless rockers Performer RPM Intake Holley 3310 780 Vacuum Secondary TH400 with 10" Continental Convertor 8.2 BOP 4 pinion 10 Bolt with 3.36 gears 11.428/118.95/1.618 |
