![]() Quote:
Even if the fan was not rotating in relation to the engine while the engine was running, it would be robbing the engine of power, because the friction of the oil would be a load (torque) on the crank. The torque*RPM/5252=HP. |
You can prevent any excess alternator drag at the track by simply turning off the fan, especially with an electric water pump. But you probably don'y want to "turn off" your mechanical fan by removing the belt. If you are using electric fans for hp reasons, you may as wel use an electric pump too.
![]() Quote:
Another point in favor of electric is that they should be able to be placed in a more efficient position, right on top of the radiator. Unless you have perfect shrouding, a closer fan will move more air through the radiator. Then you have the effectiveness of a pusher fan taking advantage of the direction the air is going in without an obstruction (the radiator) slowing the air down before it hits the fan. Imagine sitting on the engine side of the radiator. Is it easier to suck air thrugh the radiator, or to sit on the other side and blow through it? Even if you are back an inch, you get more air through the radiator, not from around it, by blowing through it, from as close as possible. You can't do this with a mechanical fan. If mechanical fans were as good, they would still be using them. Overall, a thermostatically controlled electric well placed is going to be better than any mechanical, plus it can be shut off for the few seconds of racing. |
![]() Quote:
Boy, tell you what; the mid-90's Lincoln MECH fan is probably the peak of optimal design.
While the Electric fan in fornt of it fails the 30 Amp Fuse on nearly every Lincoln. Been street-driving & towing with only the Mech fan in tha tLincoln and that Temp gauge stay put on "Normal" in all weather & driving situations. Soooooo, I tried to get me a spare Lincoln fan for the U-Pull-it (for the 68GTO) and geez it is a "Ford" design to the point of high-difficulty to transfer to the Pontiac. Could be done but at high effort. Makes me re-consider the elec fan. Butt, that Lincoln Mech fan really decouples well (the best de-clutching "neutral" I've ever seen) when not needed. ================================================ During the re-camm effort going on, I gots a Mech Fan decision to make. |
Electric fans are worth a little in the performance and mileage areas according to new car mfgs.
However *** in a HD cooling application mechanical fans are used. Every 3/4 - 1 ton Diesel truck that I've seen comes with a mechanical fan. When towing with my 460 HP, 875 TQ Diesel, I can tell the difference when the fan comes on. With my BBC Suburban, when the fan comes on while towing I lose speed. It does make a difference. Both are when towing around 10K lbs. |
Based on what I've read in performance articles they suggest it is better to have the elec fan mounted to pull air thru a radiater rather than push it thru.
![]() Quote:
Most big engines like CAT, Cummins, and Detroit use air pressure to lock and unlock the mechanical fan clutch. I used to start the Diesels in the morning with the hood open and watch the fan stay perfectly still, while the engine was running. When the fan clutch actuator opens when coolant temps get high enough the actuator opens and air pressure locks the clutch. That's when you hear some fan noise, and lots of it. HMMWV's (Military Hummers) use power steering fluid pressure to unlock the fan clutch. |
![]() Quote:
we used hummers to escort convoys in Iraq,running up and down the length to keep them in line.when that fan kicked in at 60/65 mph it was like throwing out an anchor.
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
![]() Quote:
![]() Quote:
The M939 series 5 ton vehicles fan would scare the crap out of you when it kicked in at 50 MPH. When that thing locked it made a hell of a racket. No power when locked. None.
HMMWV's have a mechanical governor in the injector pump that kicks in roughly when the speedometer is an inch past buried (60 MPH Speedometer IIRC). ![]() ![]() Last edited by Motor Daddy; 01-31-2009 at 02:07 PM. |
![]() Quote:
Bingo
https://www.flickr.com/photos/197745168@N07/ "There's nothing more unsatisfying than watching an electric car go down the dragstrip." |
Best setup imo for street strip car is oem thermal fan clutch setup.
Define "best."
New Corvettes and late model Trans Ams don't have their motors mounted sideways and they do not use mechanical fans
#38
Yea, that mid-90's Lincoln Mechanical cooling fan has to be to optimal design. Yeap.
Got 2 Lincolns and BOTH Elec fans are disabled. Yea, never notice that fan doing it's job, highways, towing, sideways, all quiet. |
#39
If you use a mechanical fan it requires the rotary motion of the crankshaft to be engaged and disengaged at a proportional ratio to the gear ratio of the pulley belt system. At some point there is work being done, whether it be friction in a bearing, or heat that is lost, etc etc. That means the system is robbing power from the engine. Power=work/time.
In an electrical circuit, when the circuit is open there is absolutely ZERO work being done. The electrical fan only works when it has to, only as much as is needed, and is way more efficient when it is doing work. Engine coolant temperatures often get hotter when the engine is run to normal operating temps and then shut down. Electric fans can and will run even when the engine is not running. Less pulley and belt system required=less maintenance. Electrical systems are generally more maintenance free than bulky heavy mechanical systems. |
#40
MD, you need to add that when an electric fan is running the load on the alternator is higher, causing an extra load on the motor.
Otherwise, I agree. |
