![]() Quote:
![]() Quote:
I bought new lower bars and ends from Calvert at a really reasonable price, put them in the lower hole and now run some preload on them. I leave off the brake at 3700 rpms and it settled the car down some. Still pulls the front end but the hit doesn't seem as violent and that also can be seen in videos of the tires.
74 GTO Bracket/Street car and another 74 for the wifey to race with! 70 GTO 400, 4 spd, #'s matching and a little to nice for me to own. Friendship is like peeing your pants..everyone can see it but only you can feel the warmth! |
![]() Quote:
Jam nuts were tight. I was able to get one side to free up some but the other side the threads were so galled up that when I tried a last ditch effort of heating the bar (ruining the powder coat), it made it worse. It only happened on the end at the back of the bar that mounts under the spring, both sides. The front heims still moved freely.
It was $59 a bar ($35 for the bar and $12 each for the heims) Plus $18 shipping.
Good to know Rob! Thanks, And thats cheap as hell! I'm going to try one time trial this week with leaving right from idle again, since i have it hooking and see if the 60 varies from the foot brake and 2 step.
Let me know how that works for you. I'm going to TNT tonight ant try different launch techniques to see if anything helps. If I have time, I'll pull the distributor and lock the timing for a back to back test on that.
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U ![]() |
![]() Quote:
I used to be able to do the same with my car and the results were the same when it 60'd in the 1.47 range. I haven't tried it yet since I re-did the car but I'd be willing to say both would be the same even with the car 60'ing mid to high 1.30's.
I didn't get a chance to try off idle today,
The weather was pretty much identical to last race with the dew point being higher today 69, and maybe a degree or two hotter around 85, 60's were 1.493, 1.498, 1.498, 1.490 1.505, then first round 1.512. 13 psi , left at 2300... car was running 10.40-41 in the heat!!
10.40 in the heat....nice! I tried a few different things at TNT Wednesday night. Nothing helped, but leaving from just off idle killed my 60' by .05. It went from 1.58 to 1.63. Leaving from 1800 to 2200 produces pretty consistent 1.58's. I tied mounting my gopro to video my tach, and you can't see it with the glare and the steering wheel in the way. I have not tried locking the timing yet.
You can get the Gopro to work. I mounted mine to the windshield, then inverted the image using my phone (gopro app since mine is Wfi). Got a pretty good idea of what my converter is doing now.
https://www.youtube.com/watch?v=tDrgBCIUCzk |
I have made several changes to my car in the quest of lower 60' times also with little to no change. My car is a 70 bird 3200# with driver. 461ci edelbrock 330 cfm heads small street roller. Turbo 400 8" PTC converter that flashes to around 5000 RPM and 3.73 gears. I have changed launch rpm from idle to 3500, I changed from 30" tall slicks to 28" tall slicks, moved timing from 34-40 degrees and locked out distributor and the car 60's 1.45 in good air and high 1.46 to low 1.47 in bad air. idle launches lower the 60' a little but anything off idle to 3500 the 60' times are almost identical. Car runs 6.50's-6.60's in the 1/8 mile and has been 10.39 at 130MPH in the quarter at norwalk in 2014.
![]() Quote:
![]() Quote:
Here is the video of my converter flash and tach response. I was trying to play around with lauch RPM during test and tune so ignore the rpm variaton at the beginning that was driver induced. LOL The converter is a tight 8" PTC specd by lane at PTC
https://www.youtube.com/watch?v=I8IPW5fJRc0 |
![]() Quote:
![]() Quote:
Rob, yes we have and it may happen at some point. |
I'm Borrowing my friends Gopro for next race for some runs to watch the tach, so we can see what my car is doing too..
#38
You guys should get a playback tach, they're not that expensive. Then you can put the GoPro under the car to see what's going on with the suspension.
http://youtu.be/zau289X213U |
#39
Got one, lol.... Need to figure out how to use it ... I could wire it into my two step wire ;cause how I have it now it's on a push button , I'll try to get that working again with my new setup.
#40
I had one. It's in the video of 68hotbirds car on his dash, lol.
