with high 1.7 60's, you will not know your performance potential until you at least stick some low 1.5's.......you are probably under stalled and under geared for the RPM range the engine wants.......couple that with drag radials.........
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
i am currently running a continental converter tight 10". I talked to chris and he said he could restall it to around 4200-4300. I also just found before the last run i made, the fuel pressure was at 7 lbs. Now the gauge is reading 5 pounds. It was a liquid filled gauge but all of the liquid has leaked out. I have read liquid filled gauges fluxuate with temps but since there is no fluid is it ok? I turned it back up to 7 lbs. I may also try open headers since its a 3.5" collectors reducing into a 3 inch pipes.
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane. |
What's wrong with drag radials???
Brian Rock '65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs. 9.88 @ 134 N/A on Cali 91 octane. http://www.youtube.com/watch?v=NJEIY5OJ68g |
PHILLYGOAT
PHILLYGOAT 1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/ 3550lbs/ Full Exhaust/ Foot Braking 1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven) More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379 GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4 |
i have run five different sets of drag radials......on a slow car to boot.....never could get any consistancy....if the track was prepped good, they hook....if the track is marginal, they don't......a set of slicks will provide consistant traction at even marginally prepped tracks.......nothing wrong with drag radials...they just won't be consistant...
mchell - Issach and I run the same drag radial at the same track on the same day - it ain't the tire unless it is just due to being too tall for the 3.73 and tight converter... He tried my looser Neil chance around 4400 stall and it ran basically the same ET as it is now... From watching the car it is really lazy on launch and really needs some 60 foot help and it isn't due to lack of traction...
1969 GTO, 3370 lbs, 10.5” tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
interesting.......I assumed that high 1.7 60's were traction limited....if that thing won't produce at least low 1.6 60's with a 4400 stall, something is definitely wrong!!!.....suspension?......may want to get it on a chasis dyno to investigate.....
When i tried the 4400 stall , the cam was retarded 5 degrees. since then i advanced the cam and havent tried the higher stall yet.
unless the cam was ground wrong, very few cars run well at 5 degrees retarded..you must get the timing events correct for your combo, but if i had to change the cam around that far back i'd be looking for a new camgrinder..
5 retard in any normal cam design would flat kill your bottom end and probably never run top end either.. |
i have already advanced it to 104. when i originaly put it in i was in a hurry and installed it straight up which turned out to be about 5 degrees retarded. I havent had the 4500 stall in it with the cam advanced yet. It will be about a week and a half before i get my converter back. I am having it restalled from the 3200 to 4300.
Rarely does any camshaft come from the grinder with a 5 degree Retard as a "straight up" spec. I have seen a lot of camshafts with advance built into them from the factory. Interesting. Who ground the camshaft for you again. Can you post the camshaft specs? All of them?
Tom V.
Perhaps it's a multi key timing set and was lined straight up in the -4 position?
those things can get wrong easy without a degree wheel on them. |
Multi-key timing sets are the worst things you can give a novice camshaft installer. I have even seen the deal get screwed up by some "experienced" mechanics/ engine builders.
If the camshaft phasing is wrong, the engine will never perform properly. I sold a Chebby guy a solid lifter camshaft and lifters many years ago. He calls me up on Memorial Day and tells me that I sold a hydraulic camshaft vs the solid lifter camshaft he wanted. The valvetrain is making a lot of noise. I say the camshaft I sold you is a solid lifter LS-6 (454 cid) camshaft with solid lifters. If you want, I will try and help you figure out the problem. I say: "Did you install the camshaft correctly?" He says, Yes, of course I did. It was "dot to dot" I drive 45 miles one way to his house on a holiday because he was acting like an a$%hole. I get there and see he has a LS-6 crate motor in the car. We take the valve covers off and every rocker is loose. I say "Did you check the lash properly?" He says I set the lash three times, I could not check it after that as the POS starter nose broke off." I say "We don't need the starter to check stuff, we can bar the engine over by hand". This is what I found: Every pushrod was bent. (That explained the broken nose on the starter). I tell him "Let's check the timing gear settings on more time" He swears that the gears are "dot to dot". We get the cover off and I look at the timing set. It is a multitooth deal. He has actually timed the camshaft three teeth off vs the proper marks. The engine "would still run", he said, but "idled rough". He blamed this on the "massive size" of the camshaft. We pull the heads and every piston has a dent in the piston top, every guide in the head is cracked, and several camshaft lobes are hurt. We pull the camshaft and he throws it down on the concrete floor breaking it in two pieces. He eventually swapped another set of heads on the engine. Bought a new camshaft from someone else (exact same grind for $100.00 more than he paid me), and got the thing running with a buddy's help. Last thing I heard about him, he torched a groove across the block between two cylinders learning about NOS. Sad but true. Tom V.
Tom he got the info/cam from Butler. I can't imagine Butlers recommending a retarted cam for a na application. Something is terribly wrong with this combination....terribly wrong.
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
Agree my Friend, Totally Agree.
Tom V.
The cam was a custom grind with no advance ground in. it was 5 degrees retared becuase i was running an old standard loose 9 way timing chain and i should have been running a .010 under chain and didnt degree it. I have since changed it to a new 9 way .010 under chain re-checked everything, degreed it and it came in at 104.5, its a 110lsa to be installed at 106 icl and since i know it is a Big cam for this compression i advanced it 2 degrees. The lash is .026 i set it .024 cold. I have custom length pushrods and am running 999 comp springs with 1.65 rockers that i had to clearance on the pushrod side of the trunion so at full lift the pushrod would not bind on the back of the rocker.(longer valves and a .440 lobe is what i was told was the reason for that) The last run i made had 80/88 jets in. I am going to try 84/90. Heres the cam: duration @.050 272/276 lobe .4400/.4410 gross lift .660/.661, valve open @ .050 int open-30btdc/close 62, exh open-72bbdc/close 24 atdc. specs for icl at 106 110 lsa.
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane. Last edited by issach428; 08-01-2008 at 10:05 PM. |
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
#38
.726 yes, but subtract lash .024 just over .700. I had a machine shop set it up and i rechecked for retainer clearance and everything was fine. oh and they are comp cams 1.65 ($330 ones)
