Sometimes those check valves just rust shut.
They should be checked periodically.
1978 Pontiac Grand LeMans.......out next year Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs. |
So,do I win a prize?A quart of used oil perhaps?
Mark 1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD.... 1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs (1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor 8.97@148.63 on 150 shot |
No real prize Bro, but I'll send you one of my DVDs if you send me your address in a PM! We gotta stick together on here ya kno!
Great advice, and come to think of it, that was the side the head gasket let go, hhhmmmm? Between that and the backfire had to be the cause of it locking up the way it did, I think I'll just replace both of them just on G.P.! (always better to be safe than sorry)
I'm just messin' with you,we all help each other.Just curious,what kind of dvd did you do?
here's the trailer~~> http://videos.streetfire.net/Player....6-EA113B54C5C8 |
How's the oil pressure deal ????
When Pontiac went to the 1258 in '67 with the 400 engine it was smaller than previous years (60-66) using the 1049..NAPA filters..BUT the earlier 1049 filters had no by-pass valve nor anti-drain back valve.. The 1258 does have a anti-drain back but NO bypass....relys solely on filter housing BP valve...I don't know about swaping filters to get the larger 1049 without the ADB valve ??? Pontiac engineers were pretty smart.. The 1258 was also used on AMC but they mounted them horizontal and oil would drain out without ADB valve. Pontiac (stock) mounts almost vertical !!?? I did run the 1049's (with 60 filter housing) on my car for the larger capicity, didn't notice any problems. My starter is seperate from ignition so I spin it over before firing...
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
