Closed Thread
Old 01-07-2022, 11:22 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Good choice, George. You need both port and hat injectors for tuning and the Ron's systems are made here in Tucson.
I ran a Ron's system when I was running NA and was very happy with it (still have it in storage). I only went with the Birdcatcher for a more traditional look when I added the blower.
IMO, a mechanical injection system is WAY better for a Roots-blown engine than any other option. It's simple, easy to tune and not too expensive.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #362
Old 01-09-2022, 10:47 AM
GTOGEORGE's Avatar
Jim
I hope so, I have a few things to figure out before I pull the trigger on the system. My car just wasn’t built to do what I’ve been trying or have been doing!
GTO George
  #363
Old 01-10-2022, 01:09 PM
GTOGEORGE's Avatar
Like i said in the above post that i have to figure out a couple things..........no.1 is where to mount the fuel pump........no.2 i need to make room for the fuel pump mandrel drive.
My car was built for a BBC engine with the fuel cell in back not a Pontiac engine with a blower and the fuel cell in front, Im working on it....LOL!
GTO George
  #364
Old 01-16-2022, 07:48 PM
GTOGEORGE's Avatar
So i took a couple of pic of the clearance i have between my flywheel and oil pan......not much!
GTO George
ID:	582098   Click image for larger version
  #365
Old 01-16-2022, 07:54 PM
charlie66's Avatar
Hopefully you have the nut and bolt converter ! lol
My Half AN Injun.....
  #366
Old 01-16-2022, 07:58 PM
GTOGEORGE's Avatar
The bolt goes through the flywheel and screw into the convertor......no nut, but i do have to shave off some on the head of the bolt some to help with the clearance. Thats why I'm thinking of going to a belly pan set up instead of the engine diaper.
GTO George
  #367
Old 01-17-2022, 10:51 PM
charlie66's Avatar
I guess you have too try and get them angled a bit as you're installing them . Tough one ..
  #368
Old 01-18-2022, 12:08 AM
GTOGEORGE's Avatar
Installing the converter bolts is easy I rotate the flywheel so the holes line up in the area of where the starter is…. Lots of room. I shave the bolts heads down so they don’t interfere with the engine diaper.
GTO George
  #369
Old 01-18-2022, 03:47 PM
GTOGEORGE's Avatar
Finally got my engine apart so i can take it to KRE............bearings looked good after 2 years of racing!
GTO George
ID:	582190   Click image for larger version
  #370
Old 01-18-2022, 05:40 PM
opeliac opeliac is offline
GTO George
Low HP combos are usually easy on parts
Sorry George, I couldnt resist.
  #371
Old 01-18-2022, 05:56 PM
GTOGEORGE's Avatar
so You have went 5.0's in your Door car?
GTO George
  #372
Old 01-18-2022, 06:28 PM
GTOGEORGE's Avatar
Yea.....thats what i thought!
GTO George
  #373
Old 01-18-2022, 09:43 PM
GTO George
I went a 5.33 with a nitrous converter and gear...Are you smart enough to know what that means??? I can put an N/A converter and gear in it and we'll see if you can outrun it...You interested?
Edit: it has a nitrous cam too, but i'll leave that in there for you.
  #374
Old 01-18-2022, 10:11 PM
GTOGEORGE's Avatar
I’ll be at Norwalk…… I’ll race anyone!
GTO George
  #375
Old 01-18-2022, 10:14 PM
GTO George
The current door car isnt a Pontiac...If mine is together by then, i'd love to make a pass next to ya...
  #376
Old 01-18-2022, 10:21 PM
GTOGEORGE's Avatar
I’ll tell you exactly what I’m doing at Norwalk….I’m making one pass Friday then I’ll run eliminations…..then Saturday I’ll make two w16 qualifying passes and call it a day on sunyill make my last qualifying pass and run eliminations! Pick your poison!
Last year I made 13 passes!
GTO George
  #377
Old 02-11-2022, 11:37 PM
GTOGEORGE's Avatar
So next week I’m going to drop my block off to take some material of the decks on my block, that’s where I was having some problems. I also need to replace no.5 rod bearing it got some junk in there and grooved it pretty good, all the rest of the bearings are going back in. Kauffman has been doing a great job for the Pontiac community! Blocks, heads, intakes along with setting ET and MPH records with their race cars! They engines have made the most HP of any Pontiacs out there! KRETTF!
GTO George
  #378
Old 03-09-2022, 07:26 PM
misterp266's Avatar
Default GTOGeorge
Question.
Is George suspended for good? He alluded to that earlier.
It would be a shame. As much as I don’t understand him sometimes, he is after all a dedicated Pontiac racer with a lot of enthusiasm.
The forums are changing.
RBPTTFMF
You figure it out . . . . . .
" Darksiders Rule "
  #379
Old 04-23-2022, 01:15 PM
GTOGEORGE's Avatar
No, I wasn’t suspended for good, just a month…..yes this form is dying Allof us racers are moving on to Facebook and other sites where you have freedom of speech. Having a difference of opinion is not arguing this is America. Now on with this thread! Thank you everyone!!
GTO George
  #380
Old 04-23-2022, 01:37 PM
Thumbs down
GTO George
Your constant battles with a certain member and muddying up nearly every thread you participate in is why you were suspended George.
Freedom of speech on Facebook?
You’re kidding right?
Just because we don’t allow you to do whatever you please here has nothing to do with freedom of speech or censorship.
It has everything to do with trying to keep the PY forums sane.
Please leave if you’re not happy here.
Crying about freedom of speech and this is America is laughable.
Closed Thread
