#341
![]() Quote:
Timing it by ear is what helps me know that it was timed better when the dots were not lined up. It's really obvious in this case. |
#342
![]() Quote:
Stan
#343
![]() Quote:
#344
![]() Quote:
As soon as I was sure that moving the chain made it worse there was no reason to further tune it. It's really obvious it runs much worse. Who ever mis-aligned the dots knew what they were doing it seems. I just would like to know for sure what they were up to with that. Makes it hard to troubleshoot the other problem with this dot thing going on. Impossible. So if I install a better new cam and lifters, timing chain set, what's to say this part that is unknown doesn't come back to haunt me? I don't really know what caused the original problem or why the dots were off. Same thing or two different things? Just a really bad POS cam? Last edited by TAQuest; 04-07-2019 at 10:23 PM. |
#345
Same.
That tiny cam installed at 85 intake centerline would likely cause RPM to limit big time. If you degreed the current setup you would discover the cure. A better cam and timing set degreed would be even better. Then get a timing light and measure advance. |
#346
While the cam is far from optimum. And while this is a total different combination. A '65 389, 2 barrel carb, lower CR, smaller valve head, which had about that same or less cam, and would turn more than 3200 RPM under power.
Stan
#347
If you while cranking the motor and advancing the distributor can not get the motor to become hard to Crank then you Dizzy is still off.
Once the motor gets hard to Crank back up the Dizzy by rotation by 1/4" to 3/8" and you should then be well in the ball park of where things should be.
#348
![]() Quote:
#349
Hey, real good job on trying to get this solved, i'm impressed with how fast you take things apart and put it back together!
I can see your logic how messing with the timing chain symbol system made things worst and why you don't want to return there for another round of exploratory cam timing adjustments. However think of it this way, you don't have a manual for that timing chain set which can tell you what is happening and how to work it. You don't have a degree wheel to tell you that one's "timing chain set" is installed and checks out to the design parameters that it's manual says it can do. You've really rocked it doing so much on the engine. I can tell you that degree wheel setup from summit, the piston stop, some solid lifters and checking the degree wheel is a real cool job to learn how to do. I got a lot of satisfaction knowing that i installed my cam within 1 degree of the cam card. When you a buy a cam they want it installed typically 6 degrees advanced so as the chain stretches it goes back down to 0 degrees advanced. That's the general theory. Piston stop usage = correct crank shaft placement correct crank shaft placement = verification that timing cover 0 degree TIMING MARK matches the timing line on BALANCER. If you have a look at my pictures you will see my engine came with a timing set like yours.. and then i bought a new one which had more precise options, like 2* increments in both directions, a little more options and came with a good instruction manual. I like those things. manuals , lol. You are soo close , you bought a car, it's the last stage to go, hey... why don't i just make sure all components are lined up correctly, engine is camshaft timed correctly by degeeing it and you'll have that skill set available which most people don't. Hopefully i said everything correctly above, it's been awhile myself since i did my camshaft change and degree but what i learned above was from forum members way back.
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
#350
Probably just going forward with the cam swap now.
One last thing I thought of. I want to show some pictures of the receipts for the build parts. Maybe there's a clue in there. Really just making sure what I'm building. Take a look at the receipts and maybe something will jump out at you. Thanks again for the help. Last edited by TAQuest; 04-08-2019 at 07:04 AM. |
#351
#352
#353
#354
![]() Quote:
The Edelbrock carb isn't helping If you get a new cam, which I think is a good idea, make sure you also get a new timing chain with instructions Buy a degree kit and degree-in properly. I've found the crank-nut turning sockets designed to hold degree wheel work great. http://www.gaugesandgadgets.com/pro-...SABEgIyBvD_BwE
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
#355
That's a standard 400 kit correct? That crank; CRK PON383LH has the stock stroke?
#356
I know Butler makes a 383 stroker crank for a 350 Pontiac.
#357
And the 350 and 400 Pontiac cranks are really close to the same.
#358
![]() Quote:
Cubic Inch change came from bore size. Clay |
#359
Wondering why a new crank for a 400 would not say '400' in the number and have '383'. CRK PON383LH I can't cross reference that crank part number.
#360
If you look at Summit for new Pontiac cranks, their part numbers have either '400' or '455' in their part number.
