#301
I'll take 1 to. Relax & just let the wife know that the extra money that comes in for these will hepl her pocketbook to. LOL. They always like that.
#302
Technology for making low volume parts is improving all the time. Scroll down for the video.
http://www.at.ford.com/news/cn/Pages...roduction.aspx
http://www.pontiacpower.org/ |
#303
Air cleaner base
Ah guys does anybody know if there is a differance in air cleaner depth , between a standard lemans air cleaner base pan and a trans am air cleaner base ? I know there is a different air filtre for each. Reason being I modified my air cleaner base to accept a k/n filtre with k/n top. It was to tall for the ram air door to open so I had to drop the pan down . Cut around the carb bowl . Now the ram air parts list shows shows the air cleaner base is for a trans am. This will cause a issue with installation of the new ram air system for those who do not have a trans am air cleaner to lower the air cleaner so the ram air dome and upper pan will have enough clearance . Other wise you will have to cut your standard lemans air cleaner to lower it .
#305
Trans Am air cleaner base is approx. 1-1/4" more dropped than a Lemans type air cleaner base.
Steve F. |
#306
Thanks for the info. Hard to find , guess will have to modify standard assembly.
#307
WU3 RAM AIR REPRODUCTION
This is the new system I have been working on , going well trying to figure out the door attachment can not get a good look at the support rod system and how it is supported in the lid. Still some welding to do and finish off some little things and do a test fit on my car. If any body has a good picture of the flapper door attachment to the lid it would be GREAT. Seen pictures on line but hard to get a good view .
#308
Fantastic work! I'm ready to order.
#309
You are a true craftsman.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
#310
Tell us the price , I to am ready to order one from you as soon as your ready. Let us / me know when I can order one from you I really want one as soon as possible.
#311
#312
#313
Thanks. Don't know if I'll catch up to you Alvin.
BTW, Thanks to Mike Noun for the photo. It is the system on Tom Goad's wagon. Note his has the 74 GTO solenoid, while the assembly manual shows the 71-72 T/A dual solenoids.
#314
I'm ready to order also
#315
Not meaning to go off on another trail,but has there ever been any data on the performance that this system is capable of producing? I'd like to see some torque/rpm/hp readings on a a-body study.
#316
More automotive performance duct details here ==>http://www.formula1-dictionary.net/naca_duct.html |
#317
A performance 1, 2, 3... automotive placement discussion
#318
How much of a temperature change do you think the air would be coming in from a ram air system?
#319
#320
I think you would have to get some benefit from the cool air from the outside of the hood as the placement of the duct would draw in the cool dead air that would be on top of the hood. The center placement of the duct would allow cooler air from the top side of the hood to be drawn in & with the foam seal it should , should be able to get what ever outside air temp is there at the time into the the top of the carb, & it would have to be cooler then the under hood temps. So with that the cool air would be more dense so you would get a cool charge this giving you some benefit.
