#301
George you know Big Chief use to have hi-ports and then switched to E-heads (the $3200 ones) and went 3.90's...just saying.
#302
He better make a change he’s starting to suck hind tit....just saying! The red Camaro is the king! GTO George Last edited by GTOGEORGE; 04-17-2018 at 02:17 PM. |
#303
You know George he has already mopped the track with dozens of cars with better heads and bigger engines. You seem to be sure it's the fault of the Edelbrock heads.....do you realize that makes no sense to a reasonably normal person. Your thoughts are if you CAN beat them you might as well join them......that's backwards thinking.....just saying. |
#304
Racers that stay in the past.....gets past bye! GTO George |
#305
Back to the topic... Jeff's car is the most impressive in my opinion out of the ECM. He is laying down incredible e.t.'s. Obviously a well tuned combo.. car and engine.
#306
#307
X100!!!
#308
You must not of seen my post EHTTFMF. Jeff runs Eheads.
#310
I didn’t say no lol, just I plan on moving into a different head in a year or two , honestly leaning towards Barton’s hi ports , but we’ll see how this new engine goes first !!
#312
Why?
#314
I just dont know why he has not at least went to the 410+cfm E heads. Pocket change to him. |
#315
You think Big Chief is running stock valves, valve springs, retainers, and stud mounted rockers?? If he is that is pretty impressive spinning things to close to 9,000rpm with 50+lbs of boost with those stock cheap parts.
#316
Doesn't matter what I think. I doubt they charge extra to remove the rocker studs and guide plates though!
#317
I bet he has 3000 in valves and springs.
Mike McCarty You can drop the line, but you'll never kill the spirit! Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
#318
I'd take that bet.... maybe $3000 worth of valves and springs.
#319
Are you his banker? You talk to all kinds of people why not ask him why he didn't try a 410 cfm E-head.
#320
No need too,he is going CV-1s.
