#281
Unless they changed the rules a steel floor and firewall lets me wear a 5 suit. GTO George |
#282
btw... with EGT gauges... I learned the hard way that when your plugs tell you all is well the actual egt reading isnt as important... however, once your spark plugs are happy and you establish an EGT that went with happy spark plugs, its a great tool to see if things have changed or need to be looked at(or engine shut off). Same can be said for A/F meters... Plugs tell the truth! I applaud your efforts here Jim... I've been following along... hope all goes well for you! |
#283
Eric
#284
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#285
So when you going to Dyno the BAD BOY?
GTO George |
#286
No dyno--track tune-up only. I'll fire it up at Paul Carter's shop (by my neighbors' requests) and then I'll try to get involved in a track rental and start making some part passes. I've heard there have been some traction issues for quick cars out there lately, even on race nights, so a track rental would be better--10 cars or so. It'll be a couple of weeks before I fire it up.
Jim
#287
http://simpsonraceproducts.com/glove...-glove-sfi-20/ Eric
#288
Jim
#289
Yes, he had his gloves off.
Eric
#290
Well..?? any news flashes..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
#291
Ellen and I just got back from almost two weeks in Great Britain and Paris (I can say it now; don't like to announce it on the internet in advance ), so we're still adjusting to the nine-hour time difference and getting back into car mode. I synced my new (used) HP netbook to the Racepak yesterday, which amounted to re-learning everything I did when I set it up last January. I called Paul yesterday to arrange to fire it up at his shop tomorrow. I'm waiting to hear back. Also called our local NHRA chassis tech guy to come out and do a re-cert. My SFI 25.4 cert expired a year ago last March, but he told me then to wait until the car is ready to run to re-cert. So--long story short--I hope to fire it up at Paul's shop tomorrow or Friday. I will provide a full report.
Jim
#292
I have to get mine re-certed this year also, it's about a PAIN in the A$$. GTO George |
#293
We have liftoff!!!
.........but it wasn't easy. Got to Paul's shop at 9AM, added the alcohol to the fuel cell (no leaks ) and went to start it up. The temp was in the 80's, but I decided to use the gas primer to fire it up the first time. However, neither the pump nor the little solenoid seemed to be working---no power. So, after checking the fuses and giving the wires a cursory check, we decided to start on alcohol. I turned it over a bit with no success, so we checked for spark and there was none. The boxes were getting power, but no spark. So, we ran through the tests recommended by MSD in the manual. Took off the connector for the crank pick-up and shorted it to check for spark with the ignition on and a spark plug connected to the coil wire and grounded to the engine. Still no spark. At this point the MSD manual suggests substituting another coil . We called Fuel Injection Enterprises (maker of the crank pick-up), but both tech guys were out. At that point, I decided to take the car back home and work on isolating the problem before starting to replace parts willy nilly (that gets expensive). I called the MSD tech line after I got back home, but he was of very little help. He was apparently reading from the same manual I was. He did give me some resistance values to check for to check the coil, but while one was right on, the other one was too small for my $10 meter to detect.
When I originally set the ignition up, I decided to piggyback the MSD digital 8+ to the Digital 7. The Digital 7 I already had and it was working fine when I stopped racing the car almost two years ago (so was the coil). The Digital 8+ was a "lightly used" one I got on eBay at a big discount and it and the new crank pickup were the unknowns in the equation. So, I rewired this afternoon and bypassed the Digital 8+ and tried it with only the Digital 7 box. Wired that way, we got a test spark when shorting the crank trigger pickup wire, but no spark with the engine turning over. Then I got a brilliant idea. Instead of using the crank trigger pickup, I could use the trigger in the MSD distributor. I plugged my trigger wire into there instead and cranked it over to see if it had a spark. Yikes!! It started instantly and scared the **** out of both of us. I shut it off right away and we put on ear protection and got the fire extinguisher ready and fired it again. Out of deference to our neighbors (and our lungs---the car was in the garage) we shut it off after about 15 or 20 seconds. Ellen didn't spot any leaks and the oil pressure was at 80#, so everything looked good. Monday, I'll take it out to Paul's to do a real warm-up, then he'll re-torque the head bolts. In the meanwhile, I'll see if I can figure out the Digital 8+ box issues, the crank pickup and get the gas primer system working. Tomorrow, the NHRA rep comes over and re-certs (I assume) my chassis. Jim
#294
WOW!!! Good to hear Jim!! Glad you found the issue. Usually the simple things!! Cant wait to hear/see it run!! Good luck monday at Pauls!!! You probably wont sleep much tonight!!
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
#295
Yup, still up thinkin' on that crank pick-up deal.
Jim |
#296
I have a FULL face mask I wear when I fire mine up in the garage.
GTO George |
#297
Glad to hear you are making some noise!
I know what you mean about getting scared when it started, I went to fire mine up for the first time on EFI, thinking it would be a bear, but I hit the key and the thing suprised me by starting and idling right away. Makes months of work feel lots better! Love your car! It is a beautiful piece.
************************************* 463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO! |
#298
More progress today: the chassis certified to 7.50 again. I didn't think there'd be a problem, but it's nice to have it done. June of 2017 is a long way away.
My face is red about another deal, though. After I took out a bunch of tie-wraps and traced the the gas primer pump wires all the way back to their source and found no issues, I remembered that the ignition has to be on to run the primer pump. Duh! I turned on the ignition and the primer pump and solenoid are working just fine now, thanks. Also, I checked the boxes for spark and found that the original 7530T digital 7 box and the 8+ box are both working when I check them individually. I'm thinking the spark issue when they're connected together may be just a crank trigger pickup issue after all. If I can't resolve that by fire-up at Paul's next week, I'll use the distributor for the spark trigger until further notice. Jim
#299
Progress.....Neat to know it lives...
#300
link to PDF of MSD 8: MSD 8 Link to PDF of the 7530T: MSD 7530T
