Old 11-06-2009, 06:55 PM
LawnJockey's Avatar
LawnJockey LawnJockey is offline
Those should look sweet. Good luck in the show!
LJ
  #282
Old 11-06-2009, 09:19 PM
Jack Blum's Avatar
Jack Blum Jack Blum is offline
My first 68. Bought it back in 1994. Had a crappy whith paint job. Rebuilt it down to the front frame rails.
Built the EFI raod racing 68 in 1997:
My next project. 68 Conv 4 speed with AC. Want to make it Alpine blue with a white top and int:
Main 2 68's with my daily driver an '04 GTO:
TigerEFI.com (Classic Pontiac Fuel Injection)
2004 GTO Company car, 1994 TA 25th Anv, 1971 Grand Safari Wagon, 1968 GTO EFI, 1968 GTO Stock, 1968 GTO Convertible in desperate need of restoration.
  #283
Old 04-30-2011, 10:28 PM
goatsheadsoup's Avatar
goatsheadsoup goatsheadsoup is offline
Default Verdoro Green 428
kind of a sleeper...
Engine Block: 1968 Pontiac 428 with 4 bolt mains
Bore and Stroke: 4.120 X 4.00" to accommodate moly rings
Heads: Stock 1968 16 casting 1.92" intake and 1.77" Stainless
exhaust valves; (7/16" screw in studs); heads ported 253
CFM Ported by Jim Butler
Valve Springs: Comp Cams # 995- dual springs
Rocker Arms: Comp Cams Magnum Roller Tips, 1.52 to 1 ratio
Retainers: Comp Cams Steel Super Locks 10 degree # 740-16
Keepers: Comp Cams # 613-16
Valve Seals: Positive Teflon, intake and exhaust
Lifters: Crower
Push Rods: Comp CA 786 Stock Length
Crankshaft: 4.00 Stroke Pontiac Armasteel Crank,
rods and mains cut .010
Rods: Tomahawk, Forged I Beam 6.625
MainBearings: Clevite 77
Rod Bolts: ARP
Rings: Sealed Power Moly
Cam Bearings: Federal Mongul
Rod Bearings: Clevite 77
Timing Gear/Chain: Cloyes Tru Roller
Gaskets: Fel-Pro full engine set
Camshaft: Crower 60211 296/409 intake 308/516 exhaust on
108LSA Choppy Idle
Intake Manifold: Edelbrock Performer with Ram Air 1 Pan
Carburation: Rochester 4 barrel carb custom built By Cliff's Q
Jets 850 CFM
Fuel Pump: Stock mechanical pump with stock line
Exhaust: Dougs headers; 21/2” X Pipes; 18 Inch Xcellerator mufflers Flows 96% with Chrome exhust tips
Ignition: MSD Billet distributor with MSD 6AL box; AC 45S plugs set at .045; initial timing set at 14 degrees, 22 additional mechanical all in by 2800 rpm for a total 36 degrees mechanical (no vac advance)
Oil Pump: Melling High Vol 60psi;30 psi at idle 15w-40 Rotella; WIX Filter
Transmission: TH-400 Transmission, Continental converter 2800 stall; Trans Go Shift, Kit Blueprinted for 575 HP
Rear End: Stock Pontiac 10 bolt Posi Trac with 3.90 gear
Suspension/ Tires: Stock Suspension Rally IIs with chrome lip; BF Radial Ta's 245 60R 14;
Vehicle Weight: Approximately 3506
www.68goat.htmlplanet.com
My wife said if I spent any more money on that car she would leave me. I sure am gonna miss her.
