#281
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#282
Mike,
Just where are you using your velocity probe? Stan
#283
Roger that CSA, average & peak fps.
i need re-educated on the fps relation to Valve curtain (area); sure a min valve curtain ( lift x pi x Dia ) CSA makes a match for air-handling capacity. But I'm stuck at port fps needing a minimum valve lift area across piston position ( across RPM), that they both support the CFM; to support the piston peak velocity x displacement. Oh the math is time-based dynamic mass-air flow stuff. I suspect a MAX engine RPM is assumed must be that Choke RPM calc. Last edited by Half-Inch Stud; 01-04-2014 at 04:48 PM. |
#284
Outa the gutter. Meant like interior decorating type curtain area. Is there another?
#285
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
#286
What worse:
great Math skills and no dog in the fight"........or having bought & 1/4 mile-Tested EVERY potentially competitive CYL Head in your proven racecar assembly, yet not sure why 1 head gave the slightly better results. intake & carb left the same? (naw) some folks here may have a "super-power" on 1/4 mile combo insight! let's compare shall we: http://m.youtube.com/watch?v=O4QVyETjYKM |
#287
Having talked to some very knowledgeable people, the next step is a very steep learning curve with a move to CFD. Not sure that is for me. Stan
#288
This is what I ment by one of my earlier posts -- The "Basic" math will not give the whole answer -- most of the time it works - when it dosent your left scratching something and wondering why -- There is a reasone they have developed wet flow benches and other specilized tools. I belive the CFD tech is why weather forcasting has goten better over the years. But it is just another tool - -crap in - crap out
#289
Tom Vaught
#290
adapco's STAR CCM+ CFD SW has a good ability to simulate (and optimize) an intake runner. Also decent engine sim ability for combustion products too. i sat in on the 4- hour mesh traing course. http://www.cd-adapco.com/products/star-ccm-plus May take months rotting behind a monitor, but answers do come out of CFD trials. So, Stan, that's why calcs along with Rules-of-thumb boundaries provides rapid design & refinement to get 95% of optimal. Would you believe 92%? 90%? |
#291
Uhm, I asked adapco PARTICULARLY about CFD ability to handle texture, surface finish & their response was....wait for it.... Quite disapponting: they said they're not sure, and would look into that and get back to me. So, the ability to CFD model-simulate, say a propeller for Thrust & Drag (HP) vs RPM where the windward/leeward blade surface finish gets varied would not be caught by even the fine mesh because the models are not matured. So, unless you know-for-sure, CFD by anybody using any suite of algorithms is about X2 as a wet flow bench my opinion: a fella still has to experiment with textures to find out what the CHANGE in performance shows. Then asign Rule-of-thumb factors for said performance changes. Last edited by Half-Inch Stud; 01-06-2014 at 08:54 PM. |
#292
ETSLIPTTFMF
THAT IS ALL!
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
The Following 3 Users Say Thank You to LiL Jack For This Useful Post: | ||
#293
If a fella had a "really good port" with a smooth tape film inside, then replaces the tape film with films having "textures-under-test"(think 220 grit, 120, 80, 60 grit & CNC bit step patterns), then the TUTs evals could occur more quickly than CFD could provide such answers.
Revealing PERF results are related to the smooth in terms of Rules of thumb for each texture. I figure. oh and ETs slip-based evals puts ya back at POST 286 (cue it up and play it loud) Last edited by Half-Inch Stud; 01-06-2014 at 09:04 PM. |
#294
Wow, how many pages now of computer racing BS? All I know is my ports are big x huge and they work pretty good.
The Following 4 Users Say Thank You to 3fastgtos For This Useful Post: | ||
#295
Wish i could say: "But I'lll be back for you jack, and let the machine speak. that's right." but my only ride is slow, and will continue to be slow for my forsee-able Street/Strip future.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
#296
In my humble opinion, any fuel that is on the port walls, I consider to be dead and a lost cause. I also don't think there is any texture that you could apply to the surface to keep fuel from adhering to it or to reintroduce it to the air stream with out hurting that air stream. JMO
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
#297
Suppose there was a Runner/guide texture that improved fuel atomization, then a fella would need to lean-out their combo to correct the EGRs, revealing a gain. Do Piston & Chamber coatings work? Id so, then why did they work? Suggest textures be tried for HP-dyno, not Flow-bench results. |
#299
here's a story: Certain engine was delivered. Fella tears that NEW engine apart and polishes the runners, puts it together and the engine spits, farts and has trouble with loaded acceleration. Calls the builder & says hey I did so-&-so polish, Builder says " there is no ability to undo the polish to restore the texture, engine is ruined". Fella bought a new engine, and is enjoying a very responsive state-of-art HP/CID carb'd engine. We hope fuel injection will be as-good. |
#300
I don't believe there is anything that conflicts with what I said. So you think coating the chamber and top of the pistons makes hp, try it and test it. I will bet the dyno can't measure the difference. The coating will reflect heat, the chamber is the only place I want heat unless its a N2o or boosted app and as long as it does not limit me on the timing on a NA app. But if I have the cam close it wouldn't on a NA app. I think coatings are BS. IMO they don't work. At least for NA 10,000 rpm and below.
