#281
thanks for the up-date Tom. Lee
#282
Im going to try and do one.IF im around when he does it.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
#284
Hi Tom,
I saw that you did a partial block fill. Will that effect the cooling of the engine for street use? |
#285
I ran my 303 RA V short deck block with a short fill for years with no issue.The new owner of the engine has had no issues either.Tom
#286
Filling the bottom of the block eliminates the dead water space that just churns around collecting rust. When short filled, all the water that enters blocks gets pumped past the top of the cylinders[where all the heat is generated], and into the heads. I filled a 400 that is all street and it runs 180°-185°, and about 190-200° in the dead of summer here at over 100° outside, when sitting in traffic. I think it helps them run cooler myself.
#287
Paul,I would agree.Not sure about what happens to oil temp as I have never put a gauge on and also run full syn oil.Tom
#288
Any news?
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
#289
How far did you fill the 400??? Thanks Jeff Back to the topic.........
#290
Well,the day finally came.Ran the engine,made a couple pulls and its still together.We started at 36 degrees and ran OK,thought we would try 34 and it did not like it.Told Joe to let it sit,cool down,do a compression test and maybe let it sit over night and re TQ the heads and reset the valves.I would like to try 38 if everthing looks good.Looks lean,cam looks too small and I know the springs are too light.Might just call it a day and not spend any more money.37p HP at 5200 and 430 TQ at 4200.I used my Iphone for the pull but dont know how to upload.I can message or email if someone can do it.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post: | ||
#291
379 HP!Tom
#292
quite impressive! this has been a great thread!!
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
#293
Sent Joe a email that if everything looked good to put his Quick fuel carb and put at 38 degrees and make a pull and then we are done.Dont want to get in any deeper with labor or dyno time.Tom
#294
Tom, I tip my hat to you. Most guys just jaw about what they are going to "do"; you go out and do!
#295
Thanks,hate to be told something wont work IF they have never tried it!Tom
#296
I like that right out of the gate you made 430 TQ really early in the power band and you are humble about it.
1.25 HP per cube 1.42 TQ per cube. Welcome to the 1:1 club on your first shot. Yeah, I like it.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#297
The engine is 383 so we are a touch short on the 1 to 1.Maybe today,maybe not.Tom
#298
To the bottom of the outer, side freeze plugs, which is equal to the bottom of the water pump inlet holes in the front of the block.
#299
Way to go Tom. Looks good!
#300
Oh I forgot about the CI after the crank etc.. But your close!!!
