Old 10-28-2019, 07:24 PM
ta man ta man is offline
Originally Posted by slowbird View Post
Wow seems like something is not happy then.
Ya stuff happens..was talking to the local speed shop Pro Mod racer today..he said..for all the years he has raced and sold parts..(he converters are the biggest hit and miss..when you get one that works hug it and keep it close.
  #262
Old 10-28-2019, 10:21 PM
AG's Avatar
AG AG is offline
Yes. I run a Redneck Racing converter ($290) that works great in my race car that I would never change even though the prevailing theory is nothing less than a $800-1200 converter would work. 7.6 % slip across the line and stalls at 5000 rpm which I had built for my car.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
  #263
Old 10-28-2019, 10:51 PM
pastry_chef's Avatar
TheoriesTTFMF.
  #264
Old 10-29-2019, 01:48 AM
Dragncar Dragncar is offline
True. I called lane at PTC from good words here. I think it was Langer who said it.
His converter 800$ 60 footed slightly worse than my TCI 1200$ converter. MPH about the same but ran 2 tenths faster. Picked up in the middle.
Pontiacs are known for that mid range torque.
He said the same converter would even work in my 540 Gabby E head engine with a few tweaks vs the 455 I am running right now.
  #265
Old 10-29-2019, 05:14 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Continental 10 inch 3200
Do you still have the Continental?
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #266
Old 10-29-2019, 01:24 PM
Yes..and honestly even if I get the new convertor working properly..I can't see selling the Continental because I know how it works..and it has worked great behind 3 different engine combos I have ran. It was originally built for my 041 cam/6x head 455 that ran low 13's.
  #267
Old 02-23-2020, 11:40 AM
slowbird's Avatar
slowbird slowbird is offline
TA Man just wondering what winter changes/upgrades have been done?
  #268
Old 02-23-2020, 04:25 PM
I had plans, I was hoping to do Dragweek this year but just not in the cards. So no changes other than putting the Continental back in and leaving the 308's in.
This year the plan is try to get quite a few passes under my belt. I know there is more et left in the car the way it sits. A fellow board member P'M me about spacers. That is one thing I plan to do. I currently run either a one inch open or one inch tapered spacer. I want to add some spacer height to see how the engine reacts.
  #269
Old 02-23-2020, 05:51 PM
slowbird's Avatar
You have that much hood clearance to test different height spacers?
  #270
Old 02-23-2020, 05:57 PM
Depends which filter assembly I use. I don't have much room to use my cowl aircleaner..but if I use my open element aircleaner I just need to use a shorter filter..,normally with it I run a 4 inch filter.
  #271
Old 02-23-2020, 06:04 PM
slowbird's Avatar
What hood you running?
  #272
Old 02-23-2020, 08:26 PM
Its a "twin turbo" style. It came with the car when I bought it.
  #273
Old 08-24-2020, 01:49 PM
Finally getting around to working on the car. It has been a struggle this year with everything going on with personal and business life to find time for my hobby.
Current goal this year is to drop the et down into the 10.6's with the same basic combination of parts. The trusty old Continental convertor is back in as well as staying with 308 gears.
The only changes will be playing with carb spacers and testing a new carb. I'm hoping to get out this coming weekend.
  #274
Old 08-24-2020, 06:25 PM
TCSGTO's Avatar
What carb? You’re running a Holley 950 now right?
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
  #275
Old 08-24-2020, 09:22 PM
Old carb Holley 950 HP..flows 770cfm to 830cfm..Depends who you talk to..Tom V figures 770cfm so I lean that way. Stock metering blocks,50 cc acc pump on front and a billet baseplate are the only changes other than jetting and powervalve.
New carb is a Prosystem that flows in the 940cfm range.1000hp mainbody, custom calibrated Venom metering blocks, twin 50 cc acc pumps, billet baseplate..Patrick James figures it's worth a tenth or 2 over the 950HP..see what happens.
  #276
Old 08-25-2020, 09:00 AM
TCSGTO's Avatar
Pro systems has done a ton of carbs for street strip Pontiac applications. Suppose to have top notch customer service too. Should work out great.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
  #277
Old 08-25-2020, 09:16 AM
Maybe now my car will like the higher shift points. With the limited amount of track tuning with this new engine it hasn't responded to higher shift points..runs basically the same shifting at 5500 or 6000 rpm..with a tick slower shifting at 6000 rpm ..which I thought was strange..especially with the 1 /2 shift going from the 2.75 first gear into 2nd.
From dyno data from identical builds it should like a 6200 to 6400 rpm shiftpoint.
  #278
Old 08-25-2020, 09:17 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
If you run with the air cleaner might try a run without it. I was surprised how much the IA/Camaro picked up pulling off the 14x4.
Skip Fix
  #279
Old 08-25-2020, 09:23 AM
I saw that thread. Maybe the air filter was causing issues as well.I also use a 14 x 4..which should have been plenty big. I do have a Moroso airpan I used a few years back that will work for sealing to the cowl hood and directing air. Thanks..another thing to test.
If I pick up 1/4 of what you saw without an air filter I would be happy!
  #280
Old 08-25-2020, 09:44 AM
leeklm's Avatar
leeklm leeklm is offline
"it hasn't responded to higher shift points..runs basically the same shifting at 5500 or 6000 rpm"
Interesting... with nearly identical setups, my ET definitely improves running the shift points up to 6-6200.
When I was restricted to a 14x3 air cleaner due to hood clearance (was a closed air cleaner with 2-4" intake holes), I found a defenite ET improvement when running a K&N filter top. However, i am now running a 14x4 air cleaner with a sealed air pan and cowl hood, and no ET difference with or w/o the filter top.
Will be Interesting to see results of your new carb! I have a QF 850 and a QF 1000, and in back to back testing, the 850 is a touch faster for 60ft times, and identical mph on the top end.
On a related note, I will eventually start a new thread looking for suggestions to get my car a little closer to the 10.0 mark
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
