#261
Separating from what?
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
#262
fuel, SSR, critical things that separate good from bad ports.
#263
Valve and stem = necessary evil As for the rest= not necessary if designed correctly and just plain hurts power potential
#264
My engine is totally powered by unburnable dribble.
Eric
#265
Are you saying air flow from SSR , I say impossible, but who cares what I think LOL.
#266
If you are Alcohol little different story. And it is only a percentage of the fuel that would be affected , but still enough to influence power.
#267
Eric
#268
LOL, That chit don't count. I use to do Top Fuel CYL head repair for most of the NHRA teams from 1997- 2002 when I worked for this one company. What's kind of funny is just how little the cyl heads importance was. You could have an old clapped out set of heads vs a new perfect set and that chit would run the same number. More blower and more fuel!!!!!!!!!!!!
#269
Your saying air can't separate off the ssr?
#270
Comments posted on tunnelport by Darin going back to 2006
http://speedtalk.com/forum/viewtopic.php?f=1&t=3396 I really like the July 3rd "Disney land" comment by Darin, results to date prove Darin was right! related comment by Lynn last year - July 20, 2012 Quote:
http://forums.maxperformanceinc.com/....php?p=4687111 |
#271
Yup, not with the curtain area at the valve that is at the SS vs the plug side. And it is also the first available path for the air to satisfy the depression. I say no way!
#272
Ok.. so you can have it abrubt and or shaped wrong and it will still stay attached?
#273
Chad, your a air speed guy. Why is the air speed always faster on the floor near the SS ?
#274
:Its not. Especially when I'm done. but even then that doesn't mean it's stuck. The roof is just as important.
#275
Then its just in the way.
#276
So just mow it down and get it out of the way?
#277
I would like to see this.
#278
LOL its not like that and you know it.
#279
The center of the floor is the fastest. My goal is to keep the spped as close to the same as possible. Keep the roof as fast as possible. Kick the wal over. My 2.125 valve SBC has a 2.200 bowl.
#280
Hey im not trying to say you're doing it wrong, we are probably doing this more similar than we think. I know my stuff makes power as well as yours. How we get there is not important.
