#241
I was amazed at how the all thread (I used 5/16) pulled itself straight with the dowel (bent itself) and then lifted the dowel out. Those of you reading this in the future don't despair if you can't drill a hole straight into the dowel (if the engine is in the car, forget straight....it ain't happening) Drill as straight as you can and make sure you stay IN the dowel. Drill it as deep as you can, tap it and run your all thread snugly. Make sure you use a deep well socket so the dowel has room to move into the socket. Lubricate the thrust washers/nut. A 1/2" wrench then will make short work of it.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#242
"Quote:
Originally Posted by David Jones View Post I'm told the 4sp cars have some sort of advantage in room, but find that hard to completely believe. I wonder if the difference is that one has a shifter "porch" and one doesn't? A side to side comparison between the T400 and the Tremec shows not that much difference. The Tremec is square and that'll be the problem." The Dearborn and the tremec are both square on top. The Pontiac engineers solved this problem by putting it in on a 7 degree angle. Most older Pontiac bellhousings have those 4 mtg. holes. But they usually have plastic plugs in them.
Dale |
#244
Alignment done. I am officially at .0045 and Keisler wants .005 or smaller. I've spun the dial indicator/crankshaft around 1000 times and actually took the bellhousing loose and then retightened it and came back with the same reading.....009, which is divided by 2.
I realized now that I made some mistakes and left myself open to being inaccurate with the dial indicator before I ordered the offset dowels and I guess ordering the .007 dowels was just blind luck. This dial indicator was prone to slight movements "out of the box" and I didn't catch it until just a few minutes ago. All the pivots etc seemed tight but I found that an additional washer was required in 2 spots to get those joints TRULY immovable. I also discovered that I was thinking about the reading of the dial indicator 180 degrees backward. I found the "0" point of the scattershield and then spun the crank around and noted the reading. I don't have the number right here with me but it was like +26 or something at the highest reading. My feeble mind decided that that was the direction the scattersheild needed to go. NOOOOOOO. That reading is actually CLOSER to the centerline of the crank...not farther as my mind had decided. I initially installed the offset dowels to pull the scattersheild the direction I thought it needed to go and the number grew...which I blamed on the dial indicator being loose. (yes, it was also) After scratching my head over that for a while I simply slid under the GTO and stared at the situation for a while. That's when it hit me I was doing this 180 degrees backward. I took the scattersheild off, spun the dowels 180 degrees and locked them back down and retightened the scattersheild. I put the newly tight dial indicator back in place (getting pretty good at that) and spun the engine. Done. The smile nearly split my face. Dumbass..........
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 04-27-2012 at 06:17 PM. |
#245
Now that you have all of that experience aligning your bell housing, how much do you charge to do house calls?
Dale |
#246
I think the term I'd need here is priceless. Literally.........
#247
Clutch rod and bumper are installed. I may go back and Loctite the adjustment nuts on the rod for a little extra piece of mind. I still think I need a lite spring on the clutch pedal to help hold it up. The instructions noted that the brake light switch may need "adjustment" and from what I'm seeing "re-engineering" may be a better term. That'll probably be next on the hit parade.
A quick glance at the trans adapter for the jack leads me to think that the car is going to need to be a bit higher in the air. Test fitting the trans into the tunnel is coming up pretty soon.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 04-27-2012 at 09:57 PM. |
#248
Is the heim already tightened to clutch pedal? It looks like its crooked? Also what is the spacer for on other side of bolt?
There are plent of heim threads in the adjustable hex rod? Looks like a lot of threads outside of it. It is a long heim thread? Youre doing a nice job, im Just observing and asking. Looks good. You will love that trans when done. Don't forget to stake pilot Bearing in crank. |
#249
Mr. Monkey is being polite. Is that really what Keisler supplied? It looks like a complete Charlie Fox. Does that "extension" strike the brake light switch bracket?
#250
That is what Keilser supplies. It's really a nice piece. Adjustable to fit and I think when you're dealing with so many possibilities there is no other way. The spacer makes it workable in a number of different situations on that end and the threaded body with threaded ends fixes the length. To my eye it actuates the master cylinder in a nice straight line. The bolt/spacer will not contact the brake light switch holder but it appears that it will strike the switch itself when it is installed. As I noted above they say that some adjustment or modification of the bracket may be required. I think I can substitute a shorter bolt and solve any issues with interference, IF adjusting the bracket in some fashion doesn't take care of any problems. I also think I can possibly just put the bolt in the other direction. It looked tight but might go. I haven't been back to the car since I took the picture.
I didn't know about staking the pilot bearing. Just take a punch and move a little bit of metal?
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 04-29-2012 at 08:02 AM. |
#251
To stake bearing can use a big center punch and big hammer several times around bearing on end of crank. Dont be shy. Also put some green loctite around outside of bearing race. Green is a retaining compound instead of thread lock.
#252
All due respect, there's no need to stake a pilot bearing. The correct one for the car will be a snug fit. You'll be cursing yourself next time you do a clutch when you're trying to remove the old one from the buggered up crank flange.
Jeff |
#253
X2
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher |
#254
i suppose do whatever you are comfortable with.
my bearing required a socket to tap in with a hammer. i did not stake it like it should have been. i kind of staked it, but i didn't want to stake it too much. i pulled TKO after 600 miles to fix broken flywheel teeth. bearing fell out into bellhousing when pulled the trans. it was weird because i didn't think i had any problems with clutch in. there is a shoulder on the mainshaft on trans that kept it from coming all the way out when i was running it. after it was reinstalled and staked tight, the clutch in at idle was the same and fine, but i noticed an improvement with shifting under load. so many things with this hobby are uncertain, but for me i'll stake it in from now on. my runout tolerance was well within requirements. |
#255
I hate to burst your bubble but I believe its .005 TIR which means "Total indicator reading"
That means you can't divide by 2. I could be wrong but you may want to double check. .009 seems quite a bit off to me.
No bubble bursted, David is right. Total needle movment has to be under .010 and you divide that by 2.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
#257
I believe TIR is more accurately referred to as Total Indicated Runout although I've often seen Total Indicated Reading used interchangeably. To get Concentricity, which is what we're after, you divide TIR by 2. There are a bunch of good youtube videos on how to dial in a bellhousing if you want to check further.
1967 Firebird Convertible Factory 400/4spd Now 462/5spd Fuel Injected http://1967firebird.atwebpages.com/ |
#258
The bearing was a very tight fit. I gently drove it in with a socket.
#259
The video's I've seen led me to believe that you look for the difference across the diameter of the bellhousing opening, using the crankshaft as the "scribe". After that runout is found (in my case just a cat hair under .009") you divide that by 2 to get the number, since the crank is the center point. I didn't look for terms or labels, I looked at method. I think I ended up looking at it a bit backward, finding zero and then getting my reading in the + direction (effectively CLOSER to the crank center.) but the result is the same and is accurate.
I think.....
#260
David, if you end up putting a spring on the clutch pedal to hold it up, make sure to put some sort of vibration damper on it. Other wise at certain RPMs it will vibrate like crazy and be very annoying
Speaking from experience of course, hahaha I put a piece of shrink tube around the spring, worked ok
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
