#221
![]() Quote:
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#222
Very nice Mike!!
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
#223
I'm basing my statement from meteorological facts. What was the air temp? That will dictate the maximum water vapor content. And no, rain is not water vapor, so it does not affect density altitude. Rain is liquid, it is not suspended in the air.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#224
Water grains affect me at the track huge! I look at that as much or more than anything else.
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
#225
![]() Quote:
I handle moisture issues and solve problems relating to moisture for a living. I also regularly explain these conditions to engineers and environmental people. So please just let it go. If you THINK the dyno corrects for these conditions AND that the correction is a true and accurate representation then good for you i guess. I know better. I've seen the same engine hooked to the dyno make 25 hp less on consecutive days due to weather. And it was not raining. Just humid. And besides i posted the sheet.
#226
Ever seen an engine lose 20 hp on back-to-back days up to the same Dyno?
#227
Great power mike. Very impressive.
#228
Thank you all for the kind words. Time to go in the car!
#229
Great job Mike and All involved.Its fact dyno on a bad day makes less ,corrects less and you have to change tune to deal with water in the air.Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
#230
Nicely done Mike!
#231
Crank trigger? Hall effect?
#232
Maybe the low pressure air that is normally associated with rainy atmospheric conditions is where it went? Your engine is a bad Poncho and that's all I really care about. Congrats on keeping it together and thanks for sharing this info.
#233
#234
That is one bad bitch! Congrats
Flat out awesome. Congrats on results, they are the result of a lot of hard work and thinking differently. Enjoy it.
#236
Good result Mike. I'm sure the power will show in the car.
Torque had a nice sweet spot at 7700, just like you predicted. Power was down some by your predicted peak of 8600. I can hear the turning gears in your head from Iowa. Might have been the air, but I bet you get just a little more air in and out of that thing before it ever goes on the pump again.
![]() Quote:
Rain isn't the culprit directly, but a rainy day has high humidity. Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. The mind, once stretched by a new idea, never returns to its original dimensions. |
#238
I know where I dyno we wait for a nice day with low humidity. If it's raining we don't do it...
Dyno operator said HP will be down 20+ HP on a really humid or rainy day... Congrats Mike! EHTTFMF!!!
1969 GTO, 3370 lbs, 10.5 tire... 07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads |
#239
Congrats on the HP Mike....will you make Beech Bend NMCA in May?
#240
Nice HP numbers.
What was the uncorrected dyno numbers? ![]()
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
