#201
Eric, Mike, Don, and everyone who stopped by- thanks for your interest in my off-beat project.
I especially appreciate the openness of the Boss Bird crew- such a methodical approach to stretching the Pontiac performance window! Meeting tuner Jerry Newman and getting a beginner's 2-day tutorial on nitromethane was priceless! I can't adequately describe how happy I am for the success of the whole Boss Bird crew. Don- I'm aware of the thrashing you did- sorry you didn't get to where you had hoped, but I look forward to lots of DCI RA-V success stories.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) Last edited by Jack Gifford; 08-10-2016 at 02:50 AM. |
#202
Some pics of Jack's engine:
#203
Jack that is really bad a$$!!
#204
Just WOW!Tom
#205
Thanks John! Great to talk with you again.
#206
That engine is a work of art, a very interesting build.
Nice meeting and speaking with you Jack. Cool tow vehicle too! Dan |
#207
I saw your Suburban and your engine. But never did meet you. Sent from my iPhone using Tapatalk |
#208
I would have enjoyed meeting you Dave. I was probably over by the Boss Bird operation, absorbing all I could of their "methods".
#209
Crank scrapers done. Still need to fabricate a windage screen, then engine can be totally buttoned up.
This photo also shows how I re-positioned the passenger-side outer row of main studs further outboard. They now tap into the more massive spots where the reinforcing rib intersects each of the main webs (3/4" long HeliCoils). Drysump pump now being built by Dailey Engineering- 2 pressure stages, 2 scavenge stages, a centrifugal air separator stage, and provision to mount a Hilborn fuel pump on the rear. Mount for it at the rear of the intake cam is done, just need to machine a short drive stub to go between the cam and the pump. Joe Anderson (who inherited Don Zig Magnetos) is looking for an appropriate magneto. It wouldn't be a problem, except my desire for the vintage look of a Vertex mag.
#210
Looking great. The main cap movement of the fasteners shows once again, how far ahead the factory engineers were in their thinking of making the block strong. The engines were making barely 200 HP stock when the strengthening rib was designed and cast into the early blocks! You have taken what was already there and now utilized it way way beyond any Pontiac engineers wildest expectations.
#211
Windage screen done- neat directionally-perforated material from Moroso (thanks Mike!).
Engine all buttoned up. A bunch of plumbing ordered; still need to source a Hilborn 4-port.
#212
Nice work Jack.
Without rereading the whole thread any reason you didn't splay the outer main cap studs? Was block originally a straight 4 bolt drilling? If so what did you do to address the unused hole? |
#213
Stopped by at Norwalk. Impressive. At the time you were in conversation with someone. May you be successful.
#214
Bruce- no need to splay the studs. My V8 hemi with this style main caps never experienced any cap walk. Funny you should ask "what about the old holes"- truth is, the first reason for moving that row of studs was because the massive block crack repair left those holes totally filled with TIG rod! So moving the holes to the more substantial spots was a no-brainer.
sdbob- sorry I didn't get to talk with you.
#215
Thanks for the info Jack. Mounting the crank scraper on the reinforcement rib was a bit of Genius too.
Pontiac pieces, aftermarket pieces intended for Pontiacs, Pontiac inspired concepts(OHC6), and Pontiac enthusiast ingenuity are well represented here. IMO this build is just as "Traditional" as Tripower,droop snoot exhaust, 4 bolt valve covers, and the Pontiac timing cover. Many thanks for daring to be different. I hope this build inspires others. |
#216
Inspirational Jack,fair play.
#217
For those who haven't seen this engine in person. Take my word for it, pictures don't do it justice. Jack said I could post these anyway. Look at the details in the camshafts, oiling circuit and lash adjusters. It's simple and brilliant . The full circle counterweights are really cool too. Can't wait to hear it under power.
#218
Thanks Mike for photo posting- I never think to bring a camera.
Dailey drysump pump received, looks good. Pump mounting and drive stub finished. Got a good start on plumbing. As usual, time spent where not expected. Put a little air pressure to the coolant system and there's a tiny leak somewhere that I'm still chasing. Head and block both checked okay after all machining was finished. Leak cannot be at the deck, since both head and block are dry-decked. I need a better leak detection scheme than watching the bending of a match flame...
#219
Jack, if you know someone who works at a new car dealership of a good full service garage, they may have an EVAP leak test smoke machine you can borrow. With the smoke machine, you can fill the cooling system with smoke and the tiniest leak will show up. Great for oil leaks and coolant leaks on an empty system. Good luck.
#220
Mike, that smoke machine sounds like the real deal. Thanks for the useful info, as always. Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
