Old 10-12-2014, 10:21 AM
66beaumont's Avatar
66beaumont 66beaumont is offline
fusion 15x7 15x8 with 215/65r15 and 255/60r15 with moog replacement springs
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
  #182
Old 12-18-2014, 08:27 PM
20milecar's Avatar
20milecar 20milecar is offline
67 bonny 225/60/16 tt2's, wide oval a/t's, 5x5 16x7 w/4" bs. Car is on old stock springs.
  #183
Old 12-18-2014, 09:29 PM
69FIREBIRD76MM's Avatar
Default 69 firebird
Centerline revolutions 15x10, 5" bs, bfg's 275-60-15, fronts are 15x4, with 205-70-15, I had to flared the rear outer lip. 5.5" bs would have being perfect.
ID:	384864   Click image for larger version
ID:	384865   Click image for larger version
ID:	384866   Click image for larger version
  #184
Old 12-19-2014, 06:50 PM
20milecar's Avatar
Heres a couple more, you can get a better idea of the "stance". 225/60/16x7 4"bs
ID:	384950   Click image for larger version
  #185
Old 12-19-2014, 09:49 PM
JSPONT's Avatar
JSPONT JSPONT is offline
American Racing, front 17x9 rear 17x10 nitto drags on rear
  #186
Old 03-23-2015, 05:58 PM
shedgpeth4 shedgpeth4 is offline
Default 14" Rally II
The car is slammed to achieve the look. Will be updating suspension and wheels, will post with updated pictures.
  #187
Old 07-20-2015, 05:52 PM
HJones1313's Avatar
HJones1313 HJones1313 is offline
Send a message via Yahoo to HJones1313
Default My new rim and tire combo
It took some doing, but I finally got my new rim and tire combo installed. They're C5 rims, 17" x 8.5 front, with the backspacing set at 5", and 18" x 9.5 rear, with 5.5" backspacing. Offset both front and rear is 4.5", and clearance appears to be very good, the only issue being the passenger side sway bar at full lock. Tire brand and size are Goodyear F1 GS all around, 245/45-17" front, and 275/40-18" rear. I know the 'Vette haters will jump on me, but I think the rims look good, fit and fill the wheelwells perfectly, and give me a lot of rubber on the road!
ID:	403348   Click image for larger version
ID:	403349   Click image for larger version
ID:	403350   Click image for larger version
ID:	403351   Click image for larger version
Name:	C5 Corvette centercaps, modified small 02.jpg
"GTO......Gas, Tires and Overdraft"!
'70 GTO convertible, 434, 4-speed
  #188
Old 07-28-2015, 06:43 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
I get bashed alot about the 'vette wheels on my 454SS pickup. Not from the 'vette guys, but from the guys who think they were the ugliest factory wheels ever on a 'vette (I never thought so)...
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #189
Old 07-29-2015, 09:24 AM
Alanjnc Alanjnc is offline
Freaking gorgeous!!!!
Alan F
  #190
Old 07-29-2015, 04:43 PM
HJones1313's Avatar
The 'Vette rims look perfect on your SS, as though they were standard equipment.
  #191
Old 07-29-2015, 08:30 PM
torqjunki's Avatar
torqjunki torqjunki is offline
Default Old School
Here is a pic with Pro Star copies that can be bought through Summit or Jegs. I like them a lot. They balanced out real well and take the tapered seat lug nuts. Fronts are 15x6 with 4" backspacing and I run a tire that's 27" tall. The rears are available in 15x10 with 5.5 or 6.5 backspacing. I originally bought the 15x10 with 5.5 and they work fine, but I had what appeared to be sufficient room to tuck them in further, so I sold the rears and now have the 15x10 with 6.5 backspacing and run a real nice 1/2" spacer also available from Summit that fits the studs nice and tight. THe rear wheel lips are not rolled and the tire is not even close to sticking out past the body. I like the looks and the traction is much better with the big tall Nitto 555R's in the rear. THe rear tire is the 275/60. There is one size bigger, but not sure the side wall will clear and it appears that they have less tread depth than the smaller tire.
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
  #192
Old 07-30-2015, 09:59 PM
This is absolutely gorgeous!!
So clean!
  #193
Old 07-30-2015, 10:14 PM
Talking 16X8.5" C4 Corvette wheels.....where they really don't belong
My '66 VW Type II 1-ton pickup, needs to get out of 'garage prison' soon and get some use again. Drilled the front rotors and rear drums for the Chevy 5 on 4.75" (5 on 120.65mm) bolt pattern after converting to '71 bus front discs (originally 5 on 112mm) and '70 Type III IRS rear suspension and drums (originally 4 on 130mm). They bolted right up with no wheel spacers after the machine work was done.
  #194
Old 07-30-2015, 10:49 PM
Default Tempest project.....hoping to see the light of day again
Wheels both front and rear are 18X9" O.Z. Racing Ultralegerra finished in satin black, 245/40 front and 275/40 rear tires. I will likely go to 245/45s in front next time around to add a little ground clearance and help fill the wheelwells up a bit more. Backspacing is 6.57", the front uses a 1.063" thick spacer/adapter.
Brakes are C6 Z06 14" 6-piston front/13.4" 4-piston rear. Front spindles are ATS AFX forged aluminum with C6 Corvette hubs, rear end is a '71-'72 Buick/Olds 'corporate' 8.5" 10-bolt that is one inch wider overall compared to the stock '64 8.2" BOP rear.
Please pardon the poor-quality pictures, I can't get the car far enough outside of my garage for a decent shot. Ride height should settle out about another inch after all the weight is back in the car, fuel tank is empty, no fluids, no battery, etc.
  #195
Old 07-31-2015, 08:50 AM
I love those Pro Stars. Great old school look.
  #196
Old 07-31-2015, 08:52 AM
Forget about those guys Tod. Those wheels look like that could have been a factory part on that truck.
  #197
Old 10-25-2015, 09:49 PM
demonic68's Avatar
demonic68 demonic68 is offline
My '64 GTO has a set of custom-made steel wheels, powder coated gloss black. The wheels centers were removed from a set of 1956 Chevy 15X5" wheels and welded into new steel rims.
The combo consists of 15X8" rear wheels (3-1/4" backspace) with 275/60-15 Firestone Indy 500 tires, and 15X5" front wheels (3-1/8" backspace) with 205/75-15 Kuhmo touring tires.
The rear end is a Ford 9" that has been narrowed 1-13/16" per side, it measures 56-3/8" wide from drum to drum. The stock rear was 60" wide. The rear wheel wells were not cut or rolled to fit the tires, but the inner wheelhouse was hammered a bit at the very rear inside bottom corner for clearance.
The rear springs are new regular-ride coils that have been cut down by 3/4s of a coil to lower the car, Air-Lift airbags (pumped up to 10 psi) are installed in both springs. Front springs are new 1967 Firebird V8 springs, they lower the front without any mods.
I absolutely love this combination
"Some times standing for what you believe. Means standing alone"
  #198
Old 10-26-2015, 02:39 AM
74GA4door 74GA4door is offline
Default 1964 Tempest 17/18 combo
1964 Tempest 17x7 4" or 4.5" bs front with 245-45 tire and 18x8 rear 5" bs with 275-40 tire.
  #199
Old 10-26-2015, 03:11 AM
1964 Tempest 17x7 4" or 4.5" bs 245-45 tire 18x8 5" bs 275-40 tire.
  #200
Old 10-29-2015, 12:16 AM
Test fitted TTII'S on the 64 Tempest. 17x8 4.5 bs front 255-40 tire 18 x 10 rear 6" bs 295-35 tire. Fronts a title too wide and touched bottom lip of fender turning. Rears actually fit but had 1/8th to 1/4" clearance max so did not touch sitting but would not be able to drive it. A 275 width tire on the 10" would probably pull the sidewalls in for enough clearance to actually drive it.
