Old 02-26-2024, 05:17 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
As the work continues, I replaced front and rear Transmission seals and side cover gasket. Also cleaned and painted the transmission a cast iron color since that's what it is.
I also replaced the rubber bushings in the shifter after cleaning it up and loosening it up with Blaster. Cleaned and painted the shift rods and arms replacing the clips..
Then the tedious task of cleaning and painting the engine which I'm still in the middle of. I decided to use the lighter non-metallic blue engine paint (Dupli-Color SP-122) because my memory (such as it is) tells me it is closest to what the 350 in my 71 GT-37 was 45 years ago...
I'm also getting the alternator and brackets ready for re-assembly.
Hopefully the engine and trans will be bolted back in sometime in March.
ID:	629409   Click image for larger version
Name:	engine paint.jpg
ID:	629410   Click image for larger version
The Following 2 Users Say Thank You to 79 Phoenix For This Useful Post:
  #242
Old 03-01-2024, 08:58 PM
A lot of big improvements going on with that car.
You're a man on a mission .
Which engine did you decide to go with ?
  #243
Old 03-02-2024, 03:44 PM
79 Phoenix's Avatar
I went with the 400. It's a 76 2bbl engine originally out of an A or B body car... Not sure of any mods but I know the cam has been replaced about 5 yrs ago when engine was rebuilt and it has an Edelbrock intake with Quadrajet. I does have 6X heads which are probably stock. I'm thinking it's pretty much a stock late 70's 400--nothing high performance. As long as it runs good I'll be happy.
I was able to sell the other 350 I had purchased so I just have the original numbers matching 350 sitting in my driveway under a tarp.
  #244
Old 03-02-2024, 04:58 PM
79 Phoenix's Avatar
I put a second coat of paint on the engine. I used a different can but same color and it is different but closer to the blue I remember... (a little more greenish). Anyway I'm even more happy with the color after the second coat.
Name:	engine paint II.jpg
The Following User Says Thank You to 79 Phoenix For This Useful Post:
  #245
Old 03-15-2024, 11:03 AM
79 Phoenix's Avatar
Engine painted, flywheel, pilot bushing, clutch and bell housing on. I was able to center the bell almost perfect with a dial indicator.
The bell had been damaged at some time in the past as there is a patch riveted over a hole. Maybe he bottomed out on a rock or something like that. So, I worked on a high spot to get it down a few thousandths... Parallel alignment is not perfect, but I think it will be okay.
Next step is to fill the tranny with oil and install. Engine and tranny should be bolted in sometime next week.
After that, install engine, wire harness and starter,. Then finish the radiator support
ID:	630395   Click image for larger version
Name:	pilot bushing.jpg
ID:	630396   Click image for larger version
ID:	630397   Click image for larger version
ID:	630398   Click image for larger version
Name:	dial indicator.jpg
  #246
Old 03-22-2024, 02:55 PM
79 Phoenix's Avatar
Got the transmission in. Next week engine and trans will be bolted in!
ID:	630848   Click image for larger version
  #247
Old 03-27-2024, 04:35 PM
79 Phoenix's Avatar
Engine and trans in! Next clutch linkage and engine wiring harness.
  #248
Old 04-06-2024, 10:50 PM
79 Phoenix's Avatar
I've been working on the clutch linkage to get it freed up, de-rusted and painted. I replaced the bushings and retainer + fresh grease on the bell crank. Mostly installed now.
Also found the LH exhaust manifold (from 73 Firebird) on my new engine seemed too close to the lower A-arm so I got the one off my old 350. The passages on the old one are a little smaller. Pictured are the original LH next to the RH (65 GTO). I painted with 2000 degree VHT Primer.
I'm thinking the size difference isn't going to matter much since it's not really a high-performance engine.
Name:	clutch linkage 1.jpg
ID:	631685   Click image for larger version
Name:	clutch linkage 2.jpg
ID:	631686   Click image for larger version
ID:	631687   Click image for larger version
  #249
Old 04-13-2024, 10:40 AM
79 Phoenix's Avatar
Been working on a lot of tedious stuff and had to wait for a bushing to come in, but the clutch is adjusted, back-lock installed correctly (I think).
I found the 73 Firebird LH exhaust manifold is almost identical (clearance-wise) to the 71 GT-37 off the 350. So I decided to use the 73 manifold because it's a little more open and closer to the RH manifold in that respect. I removed them both and painted, the reinstalled with new gaskets.
Today I also installed the repaired radiator support. Seems okay so far but need to get the header panel and fenders on before I make adjustments and see how well everything lines up..
Also working on getting the seatbelt bolts beside the front seat out...making progress slowly. I work it back and forth and loosen about 1/16 at a time so I don't snap them. Using lots of P Blaster! Soon I will begin repairing the holes in the floor.
I ordered a new front lighting harness and am waiting for that. Once I get it I will install that and engine harness and gauge hookups.
Name:	clutch linkage.jpg
ID:	631983   Click image for larger version
ID:	631984   Click image for larger version
ID:	631985   Click image for larger version
Name:	radiator support 66.jpg
ID:	631986   Click image for larger version
  #250
Old 04-13-2024, 09:55 PM
Shiny Shiny is offline
Thanks for posting the pics.
That looks like a LOT of progress! Nice!
  #251
Old 04-14-2024, 09:50 PM
79 Phoenix's Avatar
Thanks, you're welcome. I always appreciate pictures on other people's projects too. It's come a long way but still so far to go. But it's fun--mostly!
  #252
Old 04-16-2024, 06:30 PM
79 Phoenix's Avatar
I decided that since I will be waiting for the wiring harness for a few weeks I will attack the floor. The seat belts and front seat are out. No surprises in the floor.
Overall, the floor is pretty good considering its age. There are a number of smaller holes in different areas. The worst area is just inside the driver's door (not pictured). It looks to me that the driver's window was left open for a time and the carpet held moisture on the floor . Also it appears the heater core was leaking for quite a while. Here are a few pictures of the floor--more later.
Name:	back seat floor.jpg
ID:	632186   Click image for larger version
ID:	632187   Click image for larger version
ID:	632188   Click image for larger version
ID:	632189   Click image for larger version
  #253
Old 04-29-2024, 07:58 PM
79 Phoenix's Avatar
I patched the floor using a couple layers of fiberglass mesh with resin. Worked great just like the several holes in the trunk. I painted with Rustoleum rusty metal primer. I also undercoated the patched areas underneath and still need to do touchup black underneath.
After taking care of a few details underneath with the speedometer cable clips and parking brake cables I will move to the wiring and gauges.
I now have both the new engine harness and front lighting harness. I will plug them both into the firewall bulk head . For now I will hook up the engine wiring, starter, oil pressure, volt and water temp gauges.
The fuses in the fuse block have been in there at least 33 years... I guess I should replace them all.
Also, I stopped by a local exhaust fabricator today and it looks like when the time comes I will have them make a 2 1/2 system using Flowmaster mufflers.
I need to buy a battery because I will need one soon!
Name:	floor before 1.jpg
ID:	632891   Click image for larger version
Name:	floor before 2.jpg
ID:	632892   Click image for larger version
Name:	floor after 1.jpg
ID:	632893   Click image for larger version
Name:	floor after 2.jpg
ID:	632894   Click image for larger version
Name:	floor after 3.jpg
  #254
Old 05-09-2024, 07:55 PM
79 Phoenix's Avatar
As the work continues, I have installed speedometer cable, hung e-brake cables, and am in the process of installing the engine wire harness and gauge hookups for my mechanical gauges. It's been a learning experience for sure. But mostly finished.
I am also working on modifying the original throttle cable bracket so it will work correctly on the Edelbrock manifold and Quadrajet.
I bought a battery and the rear tires this week.
I need to install radiator, hoses, heater hoses and fan. Hopefully it will fire up next week!
Name:	REAR TIRES.jpg
ID:	633492   Click image for larger version
  #255
Old 05-09-2024, 10:37 PM
This car should have been yours a long time ago.
Its definitely getting the love now.
The vise grip shifter is my favorite part - that is real rock n roll right there.
Would leave it awhile if it will drive like that !
Nice stuff you're doing with it - congrats .
  #256
Old 05-17-2024, 07:24 AM
79 Phoenix's Avatar
Thanks Baron! I got my inspiration for the shifter from what my brother did about 60 years ago. He had a 55 Chevy 283 3 speed on the floor. He broke the shifter handle and used a pair of vice-grips... Actually, my vice-grips are just temporary. I didn't want to put the Hurst handle back on till I'm finished because I struggled a bit getting it off...
