Old 04-10-2024, 07:46 PM
1950Mercury 1950Mercury is offline
Default 66 Pontiac tri power base
Has anyone had any experience with the after market tri power bases from the parts place. #
TP3550G. Good bad or whatever. I have my rear one I can see daylight around the edge also for some reason there is a slight pinhole in each butterfly. Never seen this on a secondary carb. only primary carbs. Very small hole like .010 or so
Old 04-10-2024, 08:55 PM
tom s tom s is offline
I would get one fro Mike Wassen.He is a member here.I think tripower.com
Old 04-10-2024, 09:48 PM
GtoFM's Avatar
GtoFM GtoFM is offline
If metal to metal created a perfect seal, gaskets would be obsolete. In this case you need 2 things DAG sealer and pontiactripower.com . When dealing with specialties, like carbs, go to the ones that specialize. There are a few tri-power guys out there, but I have had great experiences with John and Mike!
Old 04-11-2024, 07:13 AM
chrisp chrisp is offline
bleed hole belongs there , loosen plate screws & close & tap on them to line up , lapping compound for firearms works excellent to seat the plates, not a fan of the brush on DAG sealer & Parts place i would stay away from
The Following User Says Thank You to chrisp For This Useful Post:
Old 04-11-2024, 09:51 AM
GtoFM's Avatar
chrisp, how does the firearms lapping compound compare to the automotive type, more or less aggressive? Do you massage the bore of the throttle body, the throttle plate or both? This sounds more permanent.
Old 04-11-2024, 02:42 PM
Dick Boneske's Avatar
DAG213 was applied to all Tri-Power end carbs from 1959 to 1966 at the factory. The pinholes (about .026") began in 1964 and used through 1966.
I use DAG213 on every Tri-Power I restore, including the ones that seal perfectly with no light visible around the edges. Sometimes, no amount of jockying the plates around the bore will result in no light visible. I have never attempted lapping compound. Here are two NOS '61-'63 end carb bases showing the factory applied DAG.
I also add the .026" holes in the end carb throttle plates. These holes were added to aid in hot starts.
If anyone needs some DAG213, I have a quart I bought last year and some small bottles with a brush to apply the liquid. These are $12 plus shipping.
Name:	Tripower Carb Bases Color 013.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 04-12-2024, 12:04 PM
Thank you Dick. I have some DAG on the way.
