Old 04-03-2024, 02:39 PM
VCho455's Avatar
VCho455 VCho455 is offline
Default Safety warning welding and brake cleaner. Never mix them!
Here is a link describing the serious health dangers involved when using brake clean on or near areas to be welded. This happened to a guy just like us.
Beware and stay safe.
https://www.brewracingframes.com/saf...ces%20phosgene
The Following 5 Users Say Thank You to VCho455 For This Useful Post:
Old 04-03-2024, 03:05 PM
grivera's Avatar
grivera grivera is online now
Wow - crazy story!! Thanks for posting.
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 04-03-2024, 04:05 PM
Dragncar Dragncar is online now
I have never understood why most people use Brakeclean as their go to for cleaning oily parts. Its meant for brakes and brake fluid is water based so it will not work as good anyway. CRC Heavy Duty Degreaser works better than carb cleaner for oily parts.
Thanks for posting the warning, I weld a lot.
Old 04-03-2024, 04:12 PM
JSchmitz's Avatar
JSchmitz JSchmitz is online now
YES!!! Burning chlorine producing phosgene! Phosgene is a poisonous gas.
Old 04-03-2024, 05:27 PM
i82much's Avatar
i82much i82much is offline
Oh come on, toughen up a little!!!
Old 04-03-2024, 06:22 PM
JSchmitz's Avatar
Care to demonstrate?
Old 04-03-2024, 06:27 PM
Cammer-6 Cammer-6 is offline
Please add welding galvanized material too
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-03-2024, 07:32 PM
promptcritical promptcritical is offline
DOT 3 brake fluid is polyethylene glycol based, not water based, if that matters to the discussion.
Old 04-03-2024, 07:46 PM
I warned a guy on another forum about this - he told me to fark off with that chemistry shiat.
The Following 2 Users Say Thank You to Scarebird For This Useful Post:
Old 04-03-2024, 10:52 PM
i82much's Avatar
absolutely not!!!
Old 04-03-2024, 11:27 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
I remember a big thread about this years ago on this forum. Im no chemist but i think this warning doesn't apply to non-chlorine brake cleaner in the green can
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
The Following 2 Users Say Thank You to jonmachota78 For This Useful Post:
Old 04-04-2024, 08:49 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
If “brake clean” doesn’t remove grease/oil, why is it commonplace to spray down new rotors with it when doing a brake job?
But yeah…high heat near chlorine? Not good bedfellows.
costs too much
The Following User Says Thank You to rolling money pits For This Useful Post:
Old 04-04-2024, 10:56 PM
einstein's Avatar
einstein einstein is offline
CRC Brakleen is a stellar product for removing oil and grease. Only the red can, not that useless crap in the green. Worse, they sell a red can at Dollar General with a yellow stripe band at the top, it's worse than the green can.
I've never found an alternate brand of brake cleaner tha takes oil film off like the true CRC product. Especially good at cleaning up after repairing engine oil leaks.
I appreciate the warnings in this thread, it's news to me and I'll be welding in future.
The Following User Says Thank You to einstein For This Useful Post:
Old 04-05-2024, 01:14 AM
It does remove oil and grease. Just not as good as carb cleaner and certainly not as good as CRC DeGereaser.
Now, while it looks like brake fluid might not be purely water based, glycol.
There is a huge difference what is in your brake system and your engine.
If you put oil in your master cylinder you will basically destroy your brake system. Water, nope. You could flush it out, bleed everything and be OK.
You wash brake parts in hot soapy water and never in a oil based solvent tank.
Carb cleaner is just better at removing oil and grease than BrakeClean.
The sticky dust ect. around your rotors is not oil based.
When I was a kid before Brake Clean was around or popular I seen my dad use a alcohol/water mix with a siphon gun and compressed air to clean around brake drums.
My father was a master heavy equipment mechanic.
Old 04-05-2024, 08:18 AM
They sell non chlorinated brake cleaner. It's all I've used for decades.
https://youtu.be/XqEydRRRwqE
Old 04-05-2024, 08:36 AM
Jay S's Avatar
Jay S Jay S is offline
Same here.
Old 04-05-2024, 09:46 AM
72projectbird's Avatar
Brake kleen is definitely a recipe for disaster when welding. I usually wipe down the material I'm welding with acetone before gluing stuff together.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 04-05-2024, 09:56 AM
george kujanski's Avatar
Back in the day, 1,1,1 Trichloroethane was used as a degreaser in various industries, even for cleaning printed circuit boards. Great stuff when used carefully...gone now because of the chlorine content.
A lot of what we now know as hazardous materials were used freely back in the day....chlorine-based stuff, asbestos, etc.
George
Old 04-05-2024, 09:57 AM
zippy's Avatar
zippy zippy is offline
I only use Acetone for cleaning before I TIG. It's much safer. Plus, all my brake clean is Non Chlorinated. Ya, Chlorinated did clean a bit better, but the risks are not worth it. Phosgene gas is very similar to Mustard Gas and we all know what that does.
Dan Pesonen
"If it ain't broke, modify somethin till it is"
The Following User Says Thank You to zippy For This Useful Post:
Old 04-06-2024, 11:04 AM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
People use brake clean because it removes just about everything with an oil base, leaves no residue and dries very quickly. I've used this to clean clock works before oiling!!
The Following User Says Thank You to Ram Air IV Jack For This Useful Post:
