Old 03-31-2024, 08:32 PM
CraigG.'s Avatar
CraigG. CraigG. is online now
Default Pushrod Valve Contact Pattern
Hey Everybody and happy Easter!
What do you think of this pattern and length of pushrod for a mild solid roller with 263 @ .050 and .631 lift with 1.5 rockers?
Sorry sideways view.
Old 03-31-2024, 08:36 PM
CraigG.'s Avatar
Sorry SAME valve SIDEWAYS
Old 03-31-2024, 08:38 PM
CraigG.'s Avatar
Another valve
Sideways again.
Old 03-31-2024, 08:57 PM
CraigG.'s Avatar
The sweep is oriented towards the outside or end of the valve away from the intake.
Wondered if a pushrod .050 shorter would center the pattern better?
Old 03-31-2024, 09:13 PM
4dblnkldude's Avatar
I think that looks pretty good. I was told by my machinist you want it past center like that. That's how I've done my 455 and the latest 400 I did.
Old 04-01-2024, 01:07 AM
Looks decent. Some say at half lift it should be in the center of the valve
Old 04-01-2024, 06:09 AM
Would be content with that as is
Old 04-01-2024, 07:22 AM
chuckies76ta's Avatar
I was told by a head guy that if the pattern is off center a bit, you want that offset to be on the intake side, not the exhaust manifold side. Hope that makes sense. There is a great video on here about push-rod pattern.
https://www.youtube.com/watch?v=o5is9BsH5OU
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick.
Best so far 9.95@134 mph. 1.43 60 ft.
Old 04-01-2024, 07:33 AM
PAUL K's Avatar
PAUL K PAUL K is offline
This is what you are looking for. If it's offset like Chuck's post describes and you're not looking to buy another set of pushrods I think you'd be fine with what you have.
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
Old 04-01-2024, 10:08 AM
CraigG.'s Avatar
The offset is toward the exhaust.
I wonder if a .050 longer or shorter would center more towards the intake side.
Also, could it narrow the Sweep?
Old 04-01-2024, 10:14 AM
65 Lamnas's Avatar
Get an adjustable pushrod from Summit. They're pretty cheap at around $20.. Then you can mess around with differing lengths and get your pattern centered and narrowed to your satisfaction
Old 04-01-2024, 12:19 PM
Scott Stoneburg's Avatar
If it's offset toward the exhaust, would lash caps help bring it back to center? It looks pretty close to me.
Old 04-01-2024, 12:43 PM
Formulas Formulas is offline
What rocker arms are involved here?
They are not all the same geometry despite being called Pontiac
I have a set of Comp ultra gold high end rockers that fit like socks on a rooster, I set them on the shelf and bought Harlan's that fit perfect, old school E'heads original valves
I put those Comps on a #13 iron head with a RA-IV valves = much better fit with the valve tip closer to the stud
If your not at the table you're on the menu
Old 04-01-2024, 01:06 PM
CraigG.'s Avatar
1.5 Harland Sharps e head
Old 04-01-2024, 08:16 PM
The pattern should start on the intake side
Old 04-01-2024, 09:24 PM
tooski tooski is offline
I used the Straub 1/2 lift method. It resulted in almost a 3/8 inch longer pushrod. It narrowed the trace considerably, but also moved the trace considerably towards the exhaust.
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 04-02-2024, 06:27 PM
blueghoast's Avatar
I second this. I've run mine that way with no problems.
GT
