Old 03-24-2024, 11:48 AM
ta man ta man is offline
Default Aftermarket Top Rad Hold down
I'm going from mechanical fan to electric fans with a shroud. Looking for a supplier that sells a top plate that holds down the rad. I've seen them before somewhere.
Old 03-25-2024, 07:30 AM
chuckies76ta's Avatar
Something like this should work. https://www.summitracing.com/parts/s...2b?seid=srese1
Are you going with fans like this with the shroud? I find they work really good as they have the rubber flaps that also allow air to flow through the radiator at high speeds.
https://www.summitracing.com/parts/t...06?seid=srese1
Old 03-25-2024, 07:32 AM
Are you doing the electric water pump at the same time?
Old 03-25-2024, 12:33 PM
I have a Derale setup with the flaps 16927.
https://www.summitracing.com/parts/der-16927
The Following User Says Thank You to ta man For This Useful Post:
Old 03-25-2024, 12:35 PM
I was going to ..but looked at the cost of a pump and a new belt setup..too pricey for now. Maybe if I start racing more.
Old 03-25-2024, 12:37 PM
Something similar to that Summit part but would like four holes in the factory location.
Old 03-25-2024, 05:33 PM
Red80TA Red80TA is offline
Find a busted shroud and trim to taste.
Old 03-26-2024, 04:49 PM
That will get going until I buy or make something.
