Old 12-17-2020, 02:26 PM
a421cat a421cat is offline
Default 1965 Transistor ignition coil numbers.
I have a 65 Catalina 421 tripower HO car that came with T/I ignition. My coil is tagged transistor ignition but it is #215. Is this a T/I coil? I can't find a reference to this number. Any help would be appreciated.
Bill.
Old 12-17-2020, 06:28 PM
Peter Serio's Avatar
You might try posting a photo, also get out a good ohm-meter, measure & post the resistance in ohms from the + to the - side of the coil. As I can recall the 65-66 Delco TI coil has different ohms resistance than a standard points ignition coil.
Maybe you could tell from the ohms if it's right for a TI car. Or someone could have just put a sticker on it?
Peter Serio
Owner, Precision Pontiac
Old 12-17-2020, 10:12 PM
Will do. I will be at my car club tomorrow and will check the ohms and take some pics of the coil.
Old 12-18-2020, 12:34 AM
joegpho joegpho is offline
Hi Bill,
My folks have the same - 65 421 HO Catalina - my father ordered TI Ignition.
I am not sure what was used when the car was back on the road in 2016 - it had been off since 1974. I shoot an e-mail to them and see what they come back with.
Old 12-18-2020, 02:38 AM
Geoff Geoff is offline
I have the info on 65 Tempest V8 coils. Trans ign part # is: 1115215.
Points ign is 1115214
214 resistance pri: 1.81-2.01 ohms. Sec 7200-9500
215 #s: .42-.50. 8700-12,400
The Following User Says Thank You to Geoff For This Useful Post:
Old 12-18-2020, 10:36 AM
Here is a page I made of some corrections and info on the 65 TI dist.
1965 TI Dist
Old 12-18-2020, 06:28 PM
Thanks to everyone who responded. My #215 ( 1115215 ) coil is indeed correct for my transister ignition.
Bill.
Old 01-04-2021, 12:08 AM
Good! Now I don't have to dig around my folk's car!
Old 02-23-2024, 03:29 AM
Scott Thelander's Avatar
hmmmm
resurected thread ..............
what does this 1115189 transistor coil fit ,,,, I thought it was 65 ,,??
and
what does my 1115005 amplifier module fit ,,, ?? 64-7 ? I find this one is assembly line correct for 64 65 with the rear cover that has the rounded edge,,,, and early gasket,,,, and early wiring plugs
both are NOS .... no boxes...coil has never been in a bracket
and the modual has no marks around the 3 mounting holes from ever having screws scrub the paint,,,
Im thinkin of sellling them as I have no use for them
I just need to list them correctly
thanks
Scott
ID:	629194   Click image for larger version
ID:	629195   Click image for larger version
ID:	629196   Click image for larger version
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 02-23-2024, 01:37 PM
gto4ben gto4ben is offline
I found the coil in the '64 shop manuals.
Name:	coil 1115189.jpg
Old 02-24-2024, 12:22 AM
bill ryder's Avatar
bill ryder bill ryder is offline
Hello Scott. My MPC does not show the 1115189 listed for Pontiac. The control unit asm,, amplifier, only has two numbers for 63-67. The 1115008 is 63-66 T.I. and the 1115010 is for the 67 T.I. Maybe a later MPC will show some more numbers.
"Bill"!
Old 02-24-2024, 10:15 AM
Bill Hanlon's Avatar
Scott
Attachment from '66 Pontiac Chassis Parts Catalog
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 03-14-2024, 11:57 PM
Bill
this coil came with a NOS 1115005 box.. early style with 3 short wires n plugs...
I find it is 64-7
the coil 1115189 was changed to a 1115176 I read over on the corvette site ...
but the part number application still illudes me...
scott
thanks ben !!!!
I think they are both 64 ......
now I can advertise them
