Crower Cam Saver or Hylift Johnson?
Hey guys, I am attempting the dreaded HFT cam installation in my 400 for my 62 GMC. I have a set of Hylift Johnson’s I bought from Paul K many years ago. I see Crower has a “cam saver” lifter.
Which is the best choice and why? Thanks
The More People I Meet, The More I Love My Dogs! |
I would pm Paul on that question.
The Following User Says Thank You to steve25 For This Useful Post: | ||
I’m using cam savers on my Crower cam and they seem good
I would say both are Good to use.... its just a roll of the dice
I you are able to do the weak single spring on break in, then the stars are all in aline... Plus a good choice of break in oil. |
Stick with what you have, the general consensus is that the lifters made in the past are better than what we are seeing today plus the HJ’s are a quality USA product regardless.
The ones you already have on hand
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
X2
X2
can you have lifters drilled for an oiling provision?
I thought it was the cam cores that were the issue???
Everything that I have read & heard points to lifters not cam cores. Plus it’s pretty much one or two suppliers for cam cores vs all the different suppliers for lifters.
Are you referring to solid roller lifters? I've had it done twice by Crower for the needle bearings. No other lifters would benefit or needed.
yeah i knew abt the solid rollers but wasnt sure if you could do something with a flat tappet as well. i googled a bit and couldnt figure out what a "cam saver" lifter really is ... how do they help?
The tiny holes in the face of the flat lifters are only for solids. Crower calls their version Cool Face. Doesn't work on a hydraulic since it would leak down all the internal pressure and fail the automatic lash adjustment. |
The Following User Says Thank You to Nobuddy For This Useful Post: | ||
Rhoads offers a $29 "Super Lube" groove.
The Following User Says Thank You to 242177P For This Useful Post: | ||
That groove is interesting. You might be able to do it yourself if you are careful and have some equipment.
I always use the lubed lifters on flat tappets solid and hydraulic. Just piece of mind for me. But if you already have a set of Johnson lifters I'd use those and roll with it.
The Following User Says Thank You to Formulajones For This Useful Post: | ||
I have never seen where the lifter is Grooved above the oil band, like show in the Rhoads pic....
Has anybody else? makes no sence to leak oil up into the lifter valley.. IMO |
I had those lifters along with the Mellings 041 cam. Still had two lifters / lobes fail.
