Old 02-14-2024, 02:28 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
Default Weighed my 68 GTO
Just an fyi for anyone curious . 1968 GTO Hdtp , all iron 400 with RA manifolds , 4spd , PS , PB , vintage air , no console , hide aways , or spare . 5th of Jim beam , 12ga 870 shotgun and near full tank of gas - 3,720lbs no driver .
When I wore a younger man's clothes
The Following 5 Users Say Thank You to locomotivebreath For This Useful Post:
Old 02-14-2024, 02:34 PM
That's pretty light for an abody.
My father's 69 got with an aluminum headed 571 and 4l80e, 12 bolt rear, power steering and brakes the only options, a full tank of gas and him sitting in it is 4120 lbs on my scales. He's a buck 50 so 3970 without driver.
https://youtu.be/XqEydRRRwqE
Old 02-14-2024, 02:36 PM
Ironically my SS Chevelle equipped identical to his but with a BBC is exactly 5 lbs heavier than his car.
My 70 formula is 3690 with a full tank and no driver. PS and pdb for options.
Old 02-14-2024, 03:11 PM
What’s a 4L80e weigh though ? I went to a CAT scale at the local Travel truck stop .
Old 02-14-2024, 03:35 PM
The Endura nose on GTOs is not light as compared to even a regular steel one or fiberglass .
So not
surprised that your BBC Chevell is only 5 lbs heavier.
Old 02-14-2024, 03:55 PM
JLMounce JLMounce is offline
A 4l80e without its factory converter is just shy of 180 lbs. Converter weight depends on what you're putting in it, but is anywhere from 50-80 lbs. It's a solid 50+ lbs heavier than a TH400.
My 69 Firebird with aluminum heads/intake, th400, moser 12 bolt, full interior, no AC was 3630 with my in it, half a tank of fuel and crafstman 150 piece toolset. I haven't weighed it since I've made changes to the brakes and swapped to a 4l80e+TSP converter
The car had standard OE 11" discs all around with iron calipers. Now has 13" front, 12" rear discs with aluminum calipers and lost the vacuum booster and iron master for an aluminum manual master.
-Jason
1969 Pontiac Firebird
Old 02-14-2024, 04:05 PM
Thanks for the reference data on your '68. What size & style of tires & wheels?
Old 02-14-2024, 04:09 PM
PunchT37's Avatar
PunchT37 PunchT37 is online now
My `71 T37 was 3660 a while back. With me in it. Iron heads, aluminum intake with headers. A/C compressor gone but, had the rest of the system.
455, t400, 12 bolt. Full interior.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 02-14-2024, 05:14 PM
So not
The goat has a fiberglass hood. It used to be lighter than the Chevelle but when he went to the MR1 block it added some girth. It's at least comparable to a BBC as far as weight so he's as nosey heavy as I am now.
When I get time I'll post pics with 4 corner percentages.
Old 02-14-2024, 06:04 PM
67drake's Avatar
67drake 67drake is online now
My ‘71 GTO is in my signature. Weighed it at Great Lakes Dragaway. I was surprised how heavy it was.
That was without me in it,as I remember, about 225 lbs. I did have about a 40 lb. toolbox in the trunk for tuning and adjustments.
edit- ya know maybe that was with me in it. Geez, so long ago I don’t remember.
13.95 @ 102.1 on street tires @ 4055lbs.
Old 02-14-2024, 06:29 PM
jerry455 jerry455 is offline
My 1977 Can Am, A Body, weighed 4465 lbs. at Milan Dragway, years ago. It was loaded with all power accessories, seats, windows A/C with 3/4 tank of gas, w/o me in it. The 1973-1977 A and G bodies were heavy. It had a 455 with cast iron 1970 intake and HO exhaust manifolds, stock turbo 400 and a 3.08:1 posi axle.
The Following User Says Thank You to jerry455 For This Useful Post:
Old 02-14-2024, 06:34 PM
mchell's Avatar
mchell mchell is offline
Just weighed my 71 with me in it….4003 lb……I’m around 200….no ac auto car.
Did have the welds with slicks on the rears when weighed this time….that shaved some weight
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
The Following User Says Thank You to mchell For This Useful Post:
Old 02-14-2024, 06:43 PM
Yea, my 68 GTO with 3/4 tank, and TH400 per below was 3670 or 3850 with me in it. Then the 4L80 made it a we 50-60 Lb more.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 02-14-2024, 07:50 PM
My street/strip 1967 GTO weighed 3725 with me and a quarter tank of gas. It had 421 with 400 heads, tubular headers. full exhaust, iron intake and Turbo 400. No PS or PB, no front sway bar but no weight saving measures. Did have aluminum wheels.
Old 02-14-2024, 07:51 PM
vicgto vicgto is offline
3832 lbs without me half tank of gas
1972 GTO
468 2 Bolt Main w/Eagle rotating assy
SD Ported 295 KRE D Ports 10.8 CR
OF Hydraulic roller w/ 1.65 stainless rockers
Performer RPM Intake
Holley 3310 780 Vacuum Secondary
TH400 with 10" Continental Convertor
8.2 BOP 4 pinion 10 Bolt with 3.36 gears
11.428/118.95/1.618
Old 02-14-2024, 08:33 PM
I have 15x7 front , 15x8 rear Repro rally IIs with cooper p215/65 front and 275/60s out back . Stock front 1 inch bar and added 7/8 bar rear . Rear upper & lower control arms are boxed , tubular rear frame braces .
The Following User Says Thank You to locomotivebreath For This Useful Post:
Old 02-14-2024, 08:42 PM
4dblnkldude's Avatar
I'll play. 81 TA with 400, ac sans compressor, 400, auto full interior, with t tops, 1/2 tank, was 3600#. 69 firebird PS, PB, aluminum heads, 5 speed, interior (with two radios) complete, 9 inch, caltracs, mono leafs was 3460# with full tank.
Old 02-14-2024, 08:56 PM
Gach's Avatar
Gach Gach is offline
Holy chit never realized 68 GTO weighed that much.
Old 02-14-2024, 09:48 PM
PAUL K's Avatar
PAUL K PAUL K is offline
As long as we're throwing numbers out there my 74 TA weighs 4100 without drive and with Honeycomb wheels. My 74 Formula was a fight to get down to 3860. I believe the 74's were the heaviest of the second generation Firebirds.
Go fast, see Elvis!
Old 02-14-2024, 10:18 PM
Gach's Avatar
Just wondering because my 68 GTO that I ran 13.20’s with, closed exhaust off show room floor. Just didn’t realize they wighted that much. The 64 GTO I had weighed, with back seat out and two fiberglass front seats weigh 3100 lbs, with out me in it.. sounds like what everyone has said the 64 GTO was the lightest.
