Old 02-08-2024, 10:54 AM
RJP_Gen1 RJP_Gen1 is offline
Default Idiot Lights - 67 Firebird 400
My car is new to me (this week)....so I will have lots of first ten questions
When I turn key to run position (not engaging starter), I expect to see the dash idiot lights. However, I only see 'GEN' light. I do not see any other lights (oil, temp).
What lights should be lit during the initial 'on' test? If only the Gen light comes on, any ideas as to why the other lights are out? Is there a fuse that might control the remaining lights? Sensors? Bulbs? Seems odd that all others would be out together.
thanks,
EDIT: Firebird 400 cone with idiot light cluster
Old 02-08-2024, 11:14 AM
The temp light will light when cranking.
The oil light should be on when key is on.
Might check the wire for the temp sender on intake.
Old 02-08-2024, 04:14 PM
Thanks, I'll check out the temp/oil light wiring and senders and post back.
Old 02-10-2024, 02:02 PM
Sport69 Sport69 is offline
Did you check the bulb itself?
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 02-12-2024, 09:38 PM
OK, so I did some diagnostics this evening. Temp light works fine when cranking.
I grounded the oil sensor wire and the dash idiot light works fine. So, I will assume the sensor is bad. I used an Ohm meter and measured 685 ohms across the sensor tab to ground. Not sure what it's supposed to be, but I'll order a new one anyway.
Thanks all!
Old 02-23-2024, 07:50 PM
Smile
I connected an oil pressure gauge and the oil pressure is great. So I then changed the oil sensor and the dash idiot lights works perfectly now. This issue is now closed…..moving on to the next one
The Following User Says Thank You to RJP_Gen1 For This Useful Post:
Old 03-04-2024, 12:02 AM
frankyboy455 frankyboy455 is offline
Good to hear......
one step at a time. Fixing all those things is very satisfying.
Old 03-04-2024, 11:02 AM
Cammer-6 Cammer-6 is offline
thanks for reporting back so others can follow progress and perhaps in years to come it helps fix others with same issues
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
