Old 02-07-2024, 03:25 PM
Tedd930 Tedd930 is offline
Barron , thank you for everything!! Very very informative… stupid question but the low options help or hurt the car? I spoke to Ron the original owner he was a kid in the service and wanted the car like this .
I am going to be curious how it will drive with no p/s or p/b !!😂😂😳😳
  #82
Old 02-07-2024, 03:34 PM
Keith Seymore's Avatar
No P/S P/B is fine. Just plan ahead a bit when stopping.
If you are rolling when turning that big steering wheel it will be no problem. Give it some space, though, when it whips back to center.
K
'63 LeMans Convertible
'63 Grand Prix
  #83
Old 02-07-2024, 05:46 PM
The wheel color wasnt an elective choice.
Somewhere on here before , there was a guide chart posted for wheel-to-body color.
Someone had a light turquoise car they were restoring and the chart called for dark turq wheels , but he went with body color out of personal preference .
And another guy didn't like his chart color and matched his to the body color - in that thread.
If that helps ring any bells to anybody about finding it.
I probably saved the chart - but all my stuff is trapped on a sick laptop.
It makes me hesitant about what would actually be correct for a barrier blue survivor.
Black works with them all pretty much , but it may not be correct
  #84
Old 02-07-2024, 06:14 PM
Its going to be a bitch to drive.
66 with PS can turn lock to lock with one finger while sitting still.
They called it wonder-touch and that's a pretty good description.
Yours will take both hands and both arms.
The brakes will take getting used to , maybe a lot of getting used to if you haven't already done a bit of old car piloting in the past.
If it were mine to keep , both would get factory power assist upgrade.
And a Posi rear axle.
And Rally Ones.
The lack of PS and PB is a minus on a convertible cruiser.
The lack of Posi is a minus on any GTO
If it were an XS TriPower/RamAir Induction with 4.33 posi axle , the Non-PS and Non-PB would be more in tune with that combo.
Your car has so much Plus Factor due to its condition that a few minuses aren't a really big deal .
I would have suspected it was a price leader lot car versus a customer special order.
  #85
Old 02-07-2024, 07:27 PM
Agreed .. I am just going to go off the original spare
And match that . I’ll know tomorrow going to check progress .
  #86
Old 02-07-2024, 08:08 PM
There's a thread that was going on just recently about manual brakes. Surprising how many still prefer them. My '66 is ps but manual brakes. I'll probably keep them. I will go to a dual reservoir though.
Old 02-07-2024, 08:16 PM
OG68 OG68 is offline
Power steering and brakes were dealer install options IIRC. I wonder how many were done at the dealership.
Mom (5'4") never had any problems steering and stopping our 68 though
2007 Cadillac SRX
Old 02-08-2024, 01:29 PM
bdk1976 bdk1976 is offline
There is a chart in the "GTO - A book of information 1964-1970" (which is essentially a collection of photocopied documents/brochures from Pontiac) that shows the steel wheel colors for 65 based on body colors, but have not seen a similar chart for 66.
I strongly suspect a barrier blue car would have come with black steel wheels when equipped with poverty caps. Fontaine Blue would seem to be the only other viable candidate, and in 65 it was only used on Fontaine Blue cars (and not on any of the other blue/bluish colors).
  #89
Old 02-08-2024, 04:51 PM
My '67 GTO and '67 Gp are both manual steering and brakes... and manual trans. They make you work and pay attention... Both cars drive and stop just fine.
1974 Formula 400 - Ram Air automatic
  #90
Old 02-08-2024, 04:54 PM
Default Confirmation of some details
Hello .. I just left the car confirmed original spare is a black rim…👍 took pic of the engine number attached .. also the tag on firewall … can someone confirm matching numbers please
ID:	628153   Click image for larger version
ID:	628154   Click image for larger version
ID:	628155   Click image for larger version
ID:	628156   Click image for larger version
The Following 2 Users Say Thank You to Tedd930 For This Useful Post:
  #91
Old 02-08-2024, 08:40 PM
Default Few more pics one very old nos part.
I found a nos distributor cap in the parts bin that came with the car .. it’s 100% GM but is red a proper color for the car? Thank you. Also check out the brake drum looks like that part number is
Also correct for the car I think ?? 🤔 any one get a chance to view previous post to help confirm engine ?
ID:	628183   Click image for larger version
ID:	628184   Click image for larger version
ID:	628185   Click image for larger version
ID:	628186   Click image for larger version
  #92
Old 02-08-2024, 09:48 PM
Goatboyjohnny Goatboyjohnny is offline
Looks like in a previous post you said you have the protect-o-plate. The engine unit number on that plate, should match the number stamped on the block above the WS. That is the only way to confirm a numbers matching engine block for 66, (other years too, just can't remember the exact range of years at the moment). I hope it matches up for year, either way, you have an awesome goat on your hands.
Johnny
  #93
Old 02-09-2024, 01:39 AM
Same as above about your engine verification.
Have to have the P-o-P
That is the only pure defacto way to authenticate.
If you do not have it , the only thing you can do is compare the date code of the block against build date of the car.
Distributor Cap is not assembly line correct for your car.
Since I don't see a date code on your front drum I suspect it is an aftermarket replacement.
And we still need to see the stampings around the valve stem of your spare wheel.
  #94
Old 02-09-2024, 08:44 AM
Ok I will get a close up of the wheel date code
Does the engine numbers provided appear to
Be year correct ? As mentioned prior I speak to
The original owner and he is 100% certain the engine
Was never replaced .. but it would be nice to confirm .
I will ask about the pop . Thank u
  #95
Old 02-09-2024, 09:50 AM
Get the date code off the engine. It will also tell what model years it could be.
  #96
Old 02-09-2024, 10:55 AM
Cammer-6 Cammer-6 is offline
red cap was normally for TI or CD ignition
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #97
Old 02-09-2024, 01:25 PM
There’s pictures bellow of the engine numbers
698534. WS
  #98
Old 02-09-2024, 02:10 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
WOW, this has become exhausting.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
The Following User Says Thank You to 60sstuff For This Useful Post:
  #99
Old 02-09-2024, 02:28 PM
The date code is back by the distributor on the block.
Looks something like J105. A letter and 2-3 digits.
  #100
Old 02-09-2024, 03:08 PM
gtospieg gtospieg is offline
WS would indicate 389 tri power 4 speed if indeed that is a 66 block.. As mentioned the date code would confirm if it is "date correct" for your car. The WS code was used in other years and can mean different things. For example: WS in 67 means 400 HO 4 speed.
