Hi,
A few questions: See pics 1. What is the correct factory finish for the hood latch catch? 2. Who sells the closest to factory correct hose that connects to the Heat Riser Chimney? 3. What is the factory correct finish / color for the Master Brake Cylinder and who sells it? Thanks! |
Part of latch facing you was black Phosphate, the lock mechanism ( pointed part off to right that moves) was Gold anodized.
"Norwood" is our resident expert, and has rebuild many of these latches. 1971 cars had cheap Alkalyd black paint . This was put on at sub assy just to keep flash rust off during transport to final assembly.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather Last edited by Formulabruce; 01-22-2024 at 11:52 PM. |
Might be the photo angle, the hood pop wire looks a bit out of shape. Random question, why was the RH end of it blue, not sure if all years.
![]() Quote:
Do you have any pics to share? Is the black phosphate finish the same as the bolts holding it in place? |
The Following User Says Thank You to hiyabradHO For This Useful Post: | ||
I have the same question on the heat riser chimney hose. Is the correct color black coated, or silver? I’ve heard either could be correct?
Dark manganese Phosphate
The Following 2 Users Say Thank You to Norwood For This Useful Post: | ||
Is that different than:
Caswell BLACK OXIDE CONCENTRATE Norwood, Are you doing any refinishing and rebuilding? |
Got my 4 latches restored by Norwood and they look fantastic.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
The Following User Says Thank You to RAJ7395 For This Useful Post: | ||
Is there any input on Q’s #2 & 3 ?
![]() ![]() Not sure anyone sells anything like original hose? What you show looks really close.
Mike/Illinois |
The Following User Says Thank You to Judge273 For This Useful Post: | ||
I have a latch as well from Norwood looks awesome super happy with it....
car looks very good Chris
Any comments on:
Heat Riser Chimney Hose and Master Brake Cylinder Finish |
What you're calling the "Heat Riser Chimney Hose" should be black. They are available from Ames, part #FN406RB and are called a "Pre-Heater shroud to air cleaner duct."
As for the master cylinder, I believe it should be black. However, it would not surprise me if others opined that it should be gray. |
Makes sense that they don't save their pics with names related to their part number.
https://amesperf-parts.s3.amazonaws.com/N180YJ.JPG https://www.ebay.com/itm/275460995704 |
I found the "Pre-Heater shroud to air cleaner duct" and the other duct have different part numbers. Were they the same material and just a different length or different materials. See attached.
Usually different lengths with a certain amount of flex built-in, but not a lot. The parts manuals listed a part number for nearly every application. Later they only had a couple but also the cut-to-length stock that many called for, and probably had a set length for each instead.
It seems suppliers changed over the years, possibly had a few at same time, going from the grey stock to a more glossy black in later years, as well as the grey papery coating. Even a bright silver foil coating appeared but have only seen it in GM service parts, always hard to know what is original in low mileage cars, even when they claim as much. |
FWIW, my '71 master cylinder was black from the factory. Came with the bleeders and had the "EB" stamp as well. Restored by W. Oxley years ago.
he did mine as well
