victor dominator intake on a 400
what do you guys think...im dropping a couple 400 blocks off at the machine shop next week, one for a 434 blower build....the other is just for the helluvit but iam taking the eagle h beam rods and ross pistons and stock crank to be balanced too.
for this extra 400, i have sm 78cc heads flowing an advertised 310cfm or the edelbrock dports 72cc out of the box. xr288 cam. intake could be victor dominator torker 2 possibly 66 tripower if this motor makes its way to my 66 although i really want that on a 455 ive got hanging around what kinda power u think is possible...and how do you guys think the victor would do on smaller cubes like this? and other than the specific lifters i have the stuff to try out the ls lifter retro fit
http://performerrpm.myphotoalbum.com/view_album.php? Last edited by performerrpm; 01-14-2024 at 09:52 PM. |
Torker 2 would work good. Victor 4500 is too big for a 400 in my opinion.
Well, I know a fella who ran 11 flat with one on a 400 with a RAIV cam. 750 carb.
Heavy 2nd gen too. Late block and after 3 or so years it severely cracked every main web. |
With a 400 cube motor if you had some real good breathing heads 320 plus CFM some decent compression and a big solid roller cam then a Victor may be a good choice. For your combo I think it would slow velocity may have a weak carb signal and be down on HP. Oh it would work but just not as good as other manifold choices.
Tim Corcoran |
In the Feb 2012 Car Craft we dyno tested a 535 ci pontiac with SD/Edelbrock heads of 340 cfm. Cam was a 248/256 hyd. roller. The Victor was down on power all the way to 5600 as compared to the Torker 2. The Victor tied with the T2 at 5800 and the power curve was flat at that rpm. The peak power was 635. The Performer RPM was strongest to 4500 RPM
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
The Following User Says Thank You to KEN CROCIE For This Useful Post: | ||
Here is the article Ken mentions if interested.
https://www.motortrend.com/how-to/cc...-alloy-indian/ Note in the picture gallery the Torker II intake with the welded ports. The manifold ports were too short for the tall CNC ports on the cylinder heads and required TIG-welding raised port tops, which needed to be machined flat and port-matched. .
dang i was hoping to put one of these victors to use, but its lookin like i might just have a 400 with a ehead d ports and a tripower on standby.
honestly if i could manage to put together a 450 hp or better 406 out of these extra parts id be happy
http://performerrpm.myphotoalbum.com/view_album.php? |
You should be able to make a easy 450 Hp out of any aluminum head even if it’s flowing only 260 cfm.
Go find this article from the Apr 1992 issue of HPP magazine. Note this level of power was made with a untouched T2.
Do they show any dyno sheets? These avg BSFC numbers look better than most engines best BSFC. Stan
Stan here’s they dyno sheet from that motor that Pete sent me back then.
I will post it up in 3 photos so you can zoom in better. In looking at the power anomalies from 5700 rpm on up I think I would really call that 400 a 467 Hp motor, what do you think ?
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 01-16-2024 at 07:34 AM. |
Nothing noted in the article of the drilling between the webs in the lifter valley I assume to increase drainage and maybe drilling the "421 hole" on the deck?
I had to add weld to my T2 to match a 320 cfm E head-ground and blasted mine to look prettier Makes me wonder if my IA Camaro might pick up bottom end going to a T2 since I have a soft 60 ft. When we dynoed it the Dominator on an adapter did not make any more HP that the 4150 like his test.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune 13.43@103.4 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs Last edited by Skip Fix; 01-16-2024 at 11:18 AM. |
The Victor shines on a 400 if the engine makes productive power above 7000 RPM. Not a lot of serious effort smaller cubic inch Pontiacs are built. The bigger engines make more power through out the RPM range and at lower level.... RPM=$$$
ok foor poops n giggles. sake.
same 71 400 .030. ross flat tops bme rods ultradyne sr cam 271/279 @050 .426 lobe on a 104 lsa and the victor seams like a lot of cam but it would put the power band up where the victor could work,i just dont know it its enough compression for that much cam in a small motor
You seem to be really hung up on building a sub-performing 400 regardless of info presented to you.
Your posting in the competition section so if you want to run that cam in a 406 cid motor then get 12 to 1 into that motor, or pick a different cam.
Your best chance to amaze all your friends and use your existing parts would be to install that cam at 100 ICL and measure your valve to piston clearance. Mill the heads to allow the the minimum. Look for a deal on a 750 cfm 4500 and tune that. The combination will most likely perfer 1.5 ratio rockers.... Sounds like a fun project. |
steve25? are you mad?....lol....relax brother take a breath....it aint that serious
Not at all!
But at least now I know this was just started by you to be a BS session, lol!
bull**** session?......lol look at you keeping the forums alive with your uplifting presence....i can see your piss poor attitude attracting the younger generations to the pontiac hobby by the....i dunno..single digits
Skip: 421 cooler yes.
oil drain back yes. Only valley drain back is at the front of the valley. Bettcha 2 quarts would never return to the pan !
