Closed Thread
Old 01-09-2024, 03:46 AM
Dragncar Dragncar is offline
There is a difference between a mechanic and a engine builder.
Mechanics send their engines out to builders to get rebuilt many times.
Quite often a builder is also a machinist.
Mechanics change water pumps and tie rod ends.
Sometimes a mechanic is good enough to be a engine builder.
  #82
Old 01-10-2024, 03:20 AM
Originally Posted by 78w72 View Post
How can rebuilding heads cause your bearing to spin ???
Mikes Reply:
Let's see if when I open up the Motor, if the Bearing is spun.
Am I the only one that has heard that "if you build the top end of a motor the bottom fails and vice versa"?
IMO, by installing all the internal parts in this motor over a Ten-year period, topping it off with Heads that were remanufactured, along with shaven Heads and a tight build, installed over an old, weak-ass, lower end, may have caused the bottom end to fail in some way.
  #83
Old 01-10-2024, 03:52 AM
Originally Posted by Dragncar View Post
There is a difference between a mechanic and an engine builder.
Mechanics change the water pumps and tie rod ends. Sometimes a mechanic is good enough to be an engine builder.
Mikes reply:
My predecessor, that began this project, was a Machinist/Mold-maker, very smart, but drank himself to death as did my brother recently. Otherwise, I would "not" have had to go over all his work. If he liked to use the computer and he didn't, he could have researched each phase of the work, as he performed each task.
After Ten years or more now, I have realized that I bought a second-hand project with a sourced-out motor, Trans. and a Posi-traction 3.23/disc rear. All just dropped into a 1979 Pontiac "F" -Body, never run nor tested either.
Good thing I did not overpay for this project.
P.S. Tomorow, I am going back to Harbor Freight to purchase a new engine stand. This working on a table isn't cutting it, I need to feel like a pro in order to get professional results. The Book is coming soon, but we have not removed the Pistons and won't until we buy the new engine stand for $89 with the coupon, complete. Lou went to the store and was in a rush to use the coupon, it was late when he got there and he had no time to get the 8-ton jack that I wanted for the RV that cost $25, on sale or some misc. supplies.
Tooling up for the Engine tare down, the saga continues...
Name:	PITTSBURGH 1000 lb. Capacity Engine Stand.jpg
  #84
Old 01-10-2024, 04:03 AM
Can we not rehash all the old crap? If someone needs it, they can go to the old threads! These things get long enough with Mikes reply! Measure the pistons on the skirt, the other numbers won't mean much. Tom
Mikes reply:
I will be sure to measure the Piston in the middle of the Skirt.
I plan on measuring the cyl. wall, in the past we measured an inch from the top and bottom, plus the center of the cyl. wall.
Should I remeasure for accuracy on the stand?
  #85
Old 01-10-2024, 04:08 AM
Originally Posted by jerry455 View Post
You can freshen heads and add a better cam in an older engine. People do it and do it all the time. That is how horsepower evolves. If you try to do that on an engine that is less than sound, then you can have poor results.
Mikes reply:
Up until the present time, we thought that the bottom end of this motor was the strongest part of the engine, now I feel that I was mistaken with that assumption, still learning...
  #86
Old 01-10-2024, 04:45 AM
Originally Posted by TRADERMIKE 2012 View Post
Mikes reply:
At least I use spell check, try it objective.
Mikes reply:
Kenth´s reply, you spoke:
"And don't blame others for your writing, which is questionable at best".
Mikes second reply:
Please elaborate on this statement, I have no clue if or when this happened or why? If I said something to cause this response. In other words, your statement went right over my head!
As far as I can tell, by using Grammer and spell check and spacing my paragraphs, PLUS "not" only using Capital letters, that I am within the forum's unwritten rules, these rules I have had to figure out through much scrutiny, as you're giving me now.
  #87
Old 01-10-2024, 07:06 AM
dataway's Avatar
dataway dataway is offline
Anyone taking over/under for how many pages?
  #88
Old 01-10-2024, 08:16 AM
P@blo's Avatar
P@blo P@blo is offline
By the time he weaves his past threads with his family history, im betting triple digits...
Did this all start on the first pf April?
The Following User Says Thank You to P@blo For This Useful Post:
  #89
Old 01-10-2024, 11:08 AM
Elarson's Avatar
Elarson Elarson is offline
Mikes Reply:
Yes.
Eric
The Following 3 Users Say Thank You to Elarson For This Useful Post:
  #90
Old 01-10-2024, 01:30 PM
Mikes reply:
Do you realize that when you typed the above statement that you had just finished posting this?
"...add to the aquation..."
The Following 4 Users Say Thank You to Greg Reid For This Useful Post:
  #91
Old 01-10-2024, 01:38 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
  #92
Old 01-10-2024, 04:29 PM
242177P's Avatar
242177P 242177P is offline
The Following User Says Thank You to 242177P For This Useful Post:
  #93
Old 01-10-2024, 04:59 PM
jamesq's Avatar
jamesq jamesq is offline
Tough call, will probably be locked first.....
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
The Following 2 Users Say Thank You to jamesq For This Useful Post:
  #94
Old 01-12-2024, 10:58 AM
Skidmark's Avatar
Skidmark Skidmark is offline
[QUOTE=TRADERMIKE 2012;6477164]Mikes reply:
Mike, let me try and make life a little easier on you.
1. Remember to always keep your threads/post as simple/concise as possible.
2. One issue per thread might also be beneficial in allowing forum members to fully understand what you are trying to accomplish.
3. Do not get combative or aggressive toward the people you are asking for help.
4. Learn to read the room(very important)
5. Read more talk less.
6. Keep random thoughts where they belong (in your head)
7. Disclose any condition you might have that would explain some of the odd/strange post.
Members here are pretty forgiving when they know what's going on.
8. Remember that members here are using deduction, logic, experience, etc. when trying to help. You should do the same. Avoiding rabbit holes is imperitive when properly diagnosing mechinical issues.
9. Concrete thinking can cause you to miss solutions. Keep an open mind because you don't know what you don't know.
Please don't take any of the above in a bad way.
I'm sincerely trying to help you improve your relationship with this forum.
Good luck.
The Following 4 Users Say Thank You to Skidmark For This Useful Post:
  #95
Old 01-12-2024, 03:53 PM
Stuart's Avatar
Stuart Stuart is offline
People, please stop piling on - just ignore this discussion if you object to Mike's posts, responding in a sarcastic or demeaning manner isn't helping any.
  #96
Old 01-13-2024, 03:26 AM
We assembled the Motor stand tonight and I have been looking through A book called: "How to rebuild Pontiac V-8s" and the 1970 - 81 "Haynes repair Manual" is on hand as well, in addition, the 1967 "Pontiac service Manual" is readily available on disc.
I ordered a set of New Engine mounts to the frame side, the rubber looked beat. Tomorrow we will use the Crain Hoist to attach the Engine to the Motor stand, so we can begin disassembly procedures.
The power steering rebuild kit came in and this is the third Pump in 10 years or more, one from Advance and that was returned, another from advance and there are no more returns left according to their rules. Hopefully we can do a better job than they do wherever Advance gets their Pumps from.
Tomorrow afternoon, I will take photos, as I remove the guts from this 1967 428 ci HO Project, adequately called: "Mikes Reply".
P.S. Rebuilding a motor from the bottom up is an informative lesson in Mechanics 101 and should "not" be measured in post counts. The reader can learn from his reading experience, so when they rebuild their own Engine someday, they may find that the PY forum is the place to be, when the Truth is sought, as I am seeking it now. Without the ridicule, that makes it hard for everyone here.
  #97
Old 01-13-2024, 03:39 AM
[QUOTE=Skidmark;6477939]
Mikes reply:
Mike, let me try and make life a little easier for you.
4. Learn to read the room (very important)
5. Read more, talk less.
8. Remember that members here are using deduction, logic, experience, etc. when trying to help. You should do the same. Avoiding rabbit holes is imperative when properly diagnosing mechanical issues.
Good luck.
Mikes reply:
I have a habit of editing each post before I answer, so that the next reader can better understand the conversation. I found that the spell check gives options and sometimes I choose the wrong one, I suck at spelling like most of you. I do the best I can do with the grammar tool.
You said:
"Disclose any condition you might have that would explain some of the odd/strange post".
Mikes reply:
You see, it's sniveling crap said like that, that many of you imply at times, don't "dish it out" and I won't have to give it back to you.
You spoke:
Good luck.
Mikes reply:
All of you should take his advice and we can move on with the task at hand.
  #98
Old 01-13-2024, 04:04 AM
Mikes reply:
equations (plural), "WELL BITE MY TOUNGE", WHAT IS A "Greg Reid". ARE YOU CRITIC?
You said: That I said!
  #99
Old 01-13-2024, 04:43 AM
Mikes reply:
Another way of saying this:
  #100
Old 01-13-2024, 05:45 AM
242177P's Avatar
Mikes reply:
Roadrage David. Reading some of his posts was quite challenging. Not only did he struggle with written English (foreign language, lived in Europe) but also suffered from dyslexia. I saw his posts in a different light after that was revealed. Another member here had a traumatic brain injury, so his recollection can suffer at times. After Trashcan was seriously injured, pain meds made for some interesting posts. Making allowances for members of our tight knit community (when it is called for) is not sNiVeLiNg cRaP, you would do well to remember that. Posting that you received a power steering rebuild kit isn't tech either, that's just a vanity post. Dear Diary...
The Following 3 Users Say Thank You to 242177P For This Useful Post:
Closed Thread
