Old 01-11-2024, 05:41 AM
w72 w72 is offline
Default New build, dumb PCV mistake?
After some years of mainly waiting on parts to materialize, my project has finally barked to life. No miles yet, but it idles fine and revs like it has an outstanding warrant. 400/467 stroker, 9.7:1, 041 cam, pretty much a fuel injected Jim Hand clone.
I'm almost sure we made a mistake by installing a sheetmetal valley pan. When I bought all the hard parts years ago, I was leaning towards a roller cam and the Tomohawk valley pan didn't exist yet, so the unbaffled valley cover was the only solution I was aware of. Now I realize it's likely going to suck a ton of oil, foul up the O2 sensor and spark plugs, and generally not work for my combo.
Would you take everything apart and swap a Tomohawk pan in, or hack up a catch can solution? Not totally opposed to a vacuum pump situation, but it seems like overkill for a hot street car and I'm not sure how feasible it is while retaining power steering and A/C in an already cramped F-body.
Any help or advise is welcome. Bonus points if you can confirm or deny that the (well respected) builder is crazy for recommending straight 30wt oil.
Old 01-11-2024, 06:45 AM
Personally I'd put the baffled pcv pan on. It's not a bad job to do in the car.
A vacuum pump would be overkill on such a mild build and frankly take up even more real estate than the ac already does, not to mention, The bracketry may not work with ac in place anyway.
https://youtu.be/XqEydRRRwqE
Old 01-11-2024, 09:43 AM
i82much's Avatar
i82much i82much is offline
Maybe just block it and run a PCV valve in one of the valve covers?
Old 01-11-2024, 09:48 AM
I have it 2nd-hand from the PMD designers, that the 2-Ply Valley cover was design- intended to condense the crankcase vapors before exiting the PCV valve.
Old 01-11-2024, 10:05 AM
grivera's Avatar
grivera grivera is offline
As Mike and Larry mentioned, pretty easy to swap a valley pan. The hardest part is deciding to do it. If the water crossover is separated you can do it without draining coolant. Of note, the Tomahawk pan may require trimming where it meets intake.
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 01-11-2024, 10:34 AM
78w72 78w72 is offline
I would use a PCV pan for street use. As mentioned put the factory pan back on, pretty easy swap on a pontiac, just need to drain the radiator about half way to get coolant low enough to pull the intake without any leaking, buy a felpro pan gasket with ultrablack RTV or just RTV that some use.
Also if you werent aware & decide to go HYD roller in the future, the early non EGR vally pans will work for most roller cams, might require slight denting on the underside for larger cams, was told of that option by Ken, the guy that first made the tomahawk pan.
As for the oil, you will get a lot of opinions on that, but the fact is if this engine is built with tighter street clearances there is no benefit to using a straight 30w oil or super thick race type oils. These engines called for 10/30 oil and if you have good pressure with that oil that is whats best to run, especially if youre in a colder climate & drive in early spring or late fall when cold the oil is thicker and needs to flow as fast as possible at start up. If 10/30 provides good hot idle psi around 20-30 I would run that weight of whatever brand you prefer.
Old 01-11-2024, 11:34 AM
I have only had one sheetmetal valley pan that did not suck oil. I think it was a KRE only had 3 holes and I used a baffled grommet. The Butler has about 15 holes and I "fogged mosquitos" with every king of baffled grommet, mesh in the line. A 2" tall extension. In fact one test drive of course there was a DPS officer who pulled me over. Let me off when I explained what I was doing.
My tomahawk factory style had to have some serious massaging in the corners to fit
Old 01-11-2024, 12:27 PM
Kenth's Avatar
Kenth Kenth is offline
1973-74 Pontiac 455 Super Duty has the PCV-valve located in the drivers side valve cover. Simple and works from factory.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-11-2024, 01:31 PM
65madgoat's Avatar
Exactly what I run and best bet I feel! Especially if keeping stock valve covers. Simple. Clean. No oil sucking. Can always add a catch can in line if needed.
Get your oil cap here:
https://www.tachrev.com/SDOilCap.htm
Old 01-11-2024, 04:35 PM
Some valve covers don;t have a baffle in the valve cover and I would worry they would suck oil without one.
Old 01-11-2024, 04:55 PM
w72 w72 is offline
I'm not sure if the original W-72 valve covers are baffled, or if there would be space to add one with 1.65:1 Crower stainless rockers.
Old 01-11-2024, 06:15 PM
mgarblik mgarblik is offline
The guy in the link has been out of those SD replica PCV systems for some time and has no plans to make any more. They were pretty pricey as well. I am considering making a production run of something similar with a good friend of mine, but nothing concrete yet. It's way more complicated than it looks, once you get into it. Probably be a year or so before we have something to sell. That probably won't help you.
Old 01-11-2024, 07:57 PM
VCho455's Avatar
VCho455 VCho455 is offline
Try the PVC in the valve cover to start and if you're not satisfied then do the valley pan. Remember almost every Chevrolet V8 in the 60's, 70's, and 80's had the PVC in the valve cover.
Old 01-11-2024, 09:20 PM
Schurkey Schurkey is offline
Yeah, the late '60s and onward, but they all had decent baffles welded to the inside of the valve cover to separate and drain the oil mist. They also had the fresh-air inlet on the opposite valve cover, so the fresh air came in at the "diagonal corner" of the engine.
An unbaffled PCV can suck an enormous amount of oil, depending somewhat on where the valve is placed.
Old 01-11-2024, 09:41 PM
Put in the proper factory or aftermarket replacement pan that’s already engineered for the job and be done with it.
Old 01-11-2024, 10:06 PM
That's what I would do. The factory PCV set-up front or rear worked very well. You can change that pan in 2-3 hours taking your time and checking the fit carefully. Rigging up a "Chevy system" by the time you fab and weld up a nice baffle will take just as long or longer.
Old 01-12-2024, 12:57 AM
VCho455's Avatar
Just like these.
https://www.summitracing.com/parts/t...yABEgJIufD_BwE
Old 01-12-2024, 02:00 AM
w72 w72 is offline
Those look like a magic bullet if you have clearance for huge valve covers. I have a brake booster and A/C bracket that would interfere.
Likely going to bite the bullet and install a Tomohawk valley pan. Wouldn't be the worst thing to take a peek at the pushrods after break in. Thank you all for the replies and advice.
Old 01-12-2024, 02:29 AM
NeighborsComplaint's Avatar
Use a baffled PCV grommet and PCV valve in the valve cover.
If you're stuck on pulling the intake, I've never found it much of a challenge and no need for a separated crossover.
Pinch the upper rad hose close to the water neck, remove it from the water neck and secure the end higher than the rad outlet. Remove any coolant from above the Tstat in the water neck using a bulb-style battery filler and remove the water neck. Use the bulb battery filler to siphon the coolant from the crossover and remove the intake.
No spillage and will just cost you a new Tstat gasket.
Triple Black 1971 GTO
Old 01-12-2024, 02:47 AM
w72 w72 is offline
Pulling the intake will be a bit more time consuming thanks to the FI system and its associated wiring. However, the very end of a long project seems like the wrong place to cut corners. I can't wait to drive it!
The Following User Says Thank You to w72 For This Useful Post:
