Modifying an early intake to fit late throttle bracket?
So I'm getting closer to firing up the 400 in my 81 Trans Am. The question is... I removed the 77 intake and installed a 70, because I hate the look of the EGR bosses there. They don't need to be some why have them there. So I have a 77 throttle bracket with the kickdown bracket as well. The 70 has one hole to mount the bracket which is slightly more rearward than the 77 intake, but there is a "mountain" there which looks like it could be drilled and tapped to an extent. How much meat is there? Can I drill it 13/64 and tap it for a 1/4" bolt? I would rather not drill into the plenum. So the engine is a 73, intake a 70, 78 throttle bracket. The idea is to get the mounts in as close a spot as possible as the 77 intake I had on there. Or anybody got a different idea?
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Wouldn't it be a million times easier to modify the throttle bracket? You could splice a 1970 (could even be off a 2 bbl) lower to a 78 upper. Or use one of the throttle brackets that were carb mounted? Dunno, thinking out loud is all.
I have a 70 intake that I had to mount a 1987 throttle, cruise and kick down cable bracket to. Yes there is only 1 bolt hole but I did drill and tap that “mountain “ boss for a 1/4” bolt so. I could us 2 mounting hold downs. Plenty of extra meat there.
I used my 78 Bracket on a 72 HO intake. It only used one bolt instead of two but worked fine.
All good points. thank you! Good ideas.
You didn't post pictures of the intake or the stock linkage and since I don't own the intake mentioned or the car I couldn't envision what you could do, but I have modified late seventies brackets to work with an early sixties Offy intake and GTO cable linkage on GTOs. You might be able to do something like that.
OH very nice! 61-63
Thread Tools | |
Display Modes | |
