Old 01-05-2024, 09:03 PM
Default Ram Air carb on '72
I have this sitting on the shelf. Its a '70 Ram Air 4 speed carb. My '72 needs a carb with correct linkage so I can make the scoop work. I am kind of reluctant to use this as it is not correct for a 455HO even though it'll work..
[ATTACH]Click image for larger version
1974 Formula 400 - Ram Air automatic
Old 01-06-2024, 01:12 AM
jhein's Avatar
jhein jhein is offline
[ATTACH]Attachment 626070
Attachment 626071[/ATTACH]
I would do it.
Old 01-06-2024, 10:33 AM
Suppose you could have the throttle body disassembled & throttle shaft changed from the earlier style to the '72 style. That would allow the correct '72 & later style cable attachment vs the earlier pin/cotter key style bolt on lever. With the shaker switch engagement on a '72 T/A being down off the gas pedal/kick down switch the style of carb lever doesn't really come into play, other than the idle stop function. If your '72 is a turbo 400 car, & missing its original T400 kick down switch, let me know, I'll look at the resistor on the side of a '72 T/A nos auto kick down switch. You can source a resistor with the correct value, so the standard kickdown switch can be modded.
Door 2, of course, source the correct 72 Qjet. sell/trade the highly desirable 7040273 for a nice 7042273 or 7042270 & cash or other hard to find parts.
Old 01-06-2024, 11:36 AM
Norwood's Avatar
Norwood Norwood is offline
Pm sent
Old 01-06-2024, 12:35 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Thumbs up
If I were you I'd swap out that carb for one my SD carbs. I'd get a correct carb for my 70 and you'd get a better performing carburetor for your 72. Seems like a win win.
You could swap out the throttle shaft, but I'd seriously look at another option and save that 70 carb for a correct application. Not hard to find a carburetor that will out perform a 70 Ram Air carb and deliver a more pleasurable driving experience.
Go fast, see Elvis!
Old 01-06-2024, 03:48 PM
That’s a nice one
Old 01-06-2024, 04:13 PM
Originally Posted by Tellyshavilli View Post
That’s a nice one
Thats why I am hesitant on putting it on the wrong car.
Old 01-06-2024, 07:26 PM
4birds's Avatar
4birds 4birds is offline
Thumbs up 1972 T/A
71GP76TA, as 'Ol Pinion head stated earlier, your 72 T/A scoop flap operates from the kickdown switch mounted on the gas pedal inside the car. (both automatic and manual trans cars)
It's not the same as the carb mounted switch like on your 70 T/A's.
It would be best to find the correct 7042273 with the bowl vent so the air cleaner base and scoop will be pointed in the right direction, also.
Name:	72 Pedal Switch.jpg
ID:	626117   Click image for larger version
Name:	72 455HO.jpg
Old 01-07-2024, 01:12 PM
I'm an idiot. I just assumed it was the same as a '70... Learn something new everyday..
Old 01-07-2024, 07:43 PM
My '72 does not have the gas pedal switch. It does appear to have the plug. The carb that is currently on the car is a ' 72 service replacement for an automatic.
Old 01-07-2024, 08:29 PM
Formulabruce's Avatar
IIRC. All non 6 cly cars in 72 got same gas pedal bracket for th400 and or shaker switch. Its a big bracket, not the one you have. Bolts behind the plastic part with same 3 screws. Wiring is built into harness. Hope you find a great solution.
Old 01-07-2024, 09:41 PM
necdb3's Avatar
necdb3 necdb3 is offline
They used the electric kickdown from the gas pedal from 72-up for a few years on automatic cars. As stated, the only difference would be the resistor when they tied in the shaker.
Old 01-08-2024, 02:00 AM
65 Lamnas's Avatar
I 'think' this one I have is a '72 carb, will have to check for sure...
Old 01-08-2024, 10:59 AM
JSuchma JSuchma is offline
I have a good used shaker/turbo 400 switch with the resistor that I pulled from a 72T/A I parted in the early 80's. PM me if interested.
Old 01-08-2024, 01:24 PM
Can you post a picture?
Old 01-08-2024, 07:39 PM
There are a few pictures of it in the 67-81 Firebird and TA parts for sale.
Old 01-08-2024, 09:28 PM
Held for Ransom's Avatar
https://forums.maxperformanceinc.com...d.php?t=868488
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 01-08-2024, 09:53 PM
Is it the shaker solenoid the same for a manual trans car?
Old 01-08-2024, 10:02 PM
PM sent
Old 01-09-2024, 12:06 AM
Yup, sure is. # 1114427, it comes with Both Solenoids hooked together
