WTB 1971 NOS Heater control valve
Anybody have an NOS heater control valve for a '71 Firebird for sale? I'm not sure what years or body styles are the same but what I need has the mounting bracket attached to it. The replacement 4 Seasons one looks identical but does not have the mounting bracket. Any help would be appreciated.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
Actually after closer inspection the the bracket come off the valve, the valve has threads on it for a nut. But still looking for the correct valve.
Is this heater control valve only used on early firebirds? All the mid to late year 2nd gen birds Ive had didnt have a separate control valve, the heater core gets full hot water all the time and the inside temp is controlled by a flapper door in the heater core box.
That is correct, as a matter of fact I believe all Pontiacs are like that with a mid Gen change...
1970 Assembly diagram, vacuum-operated heater tap with AC from 70-71 models, and fresh air vacuum door in the AC case of the 70-73 models. There was a limited run of reproduction mounting brackets for the tap a few years ago.
1970 Firebird heater tap vacuum operated evaporator case AC door (1) by Ben, on Flickr #9774799 https://www.2040-parts.com/nos-1965-...alve-i1580779/ Here's an old thread : https://forums.maxperformanceinc.com...=807846&page=3 Last edited by Red80TA; 01-06-2024 at 07:17 AM. |
bringing back nighmares of vacuum controls on my 71.
I never did find a diagram of hose schematic,just stumbled thru
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Whats part number of one you need?
#9774799?
Everything comes and goes Pleasure moves on too early And trouble leaves too slow Last edited by Cammer-6; 01-07-2024 at 07:47 PM. |
