Old 12-13-2023, 04:52 PM
tekuhn tekuhn is offline
Default Dipstick Tube w/ 4-Bolt Mains Clearance
Is there a trick to installing the short inner dipstick tube with the '65+ windage tray and 4-bolt mains? The tube wants to hit the outer edge of the #3 main cap before it can be angled properly to align with the tray and intermediate tube. I can see that this is likely not an issue with two bolt mains as the cap is narrower.
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures
Old 12-13-2023, 06:08 PM
mgarblik mgarblik is offline
I have inserted the short inner tube into the outer tube along with the tray at the same time. Lower them in together. Make sure the short tube is not upside down. Every now and then you may have to bend the inner tube just a touch at the little kink in the tube. Be careful.
Old 12-22-2023, 11:46 AM
I did get this installed OK. It's definitely touching the main cap, but the angles look good and there's no way this will ever be able to get dislodged and fall out of place.
Old 12-22-2023, 11:50 AM
AG's Avatar
AG AG is offline
It's easier to put the main cap on after the dipstick tube.
