Old 12-18-2023, 02:20 PM
SD421's Avatar
SD421 SD421 is offline
Default HO Racing Distributor Curve Specs Chart
Does anyone by chance have the chart you can post that HO Racing used to sell with their distributor/Vacuum advance kits?
It showed a comparison between stock timing and HO racing recommended vacuum advance/timing curve specs. The pic I have is too blurry to make out.
Thanks,
Don
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 12-20-2023, 03:06 PM
GPC GPC is offline
Default HO Distributor Curve
On a Sun machine, my HO modified stock distributor has 12 degrees all in at 2800 rpm. Did not check vacuum advance.
