Engine Fogging Spray?
Hey Guys,
What are some good engine fogging sprays for e85 or alcohol motors storage? Thanks, Craig |
Foggit works well. Lots of drag racers using it with all types of fuels.
Sea foam or similar brands work great and are cheap priced and easy to find at most any auto or home stroes.
https://www.walmart.com/ip/STA-BIL-2...m&gad_source=1 https://www.walmart.com/ip/STA-BIL-2...m&gad_source=1 |
Can I ask a stupid question without completely hijacking this thread? What’s the proper way to apply fogging oil? I’ve heard of pulling plugs and spraying the cylinders but I’ve also heard of spraying down the carb with the engine running. What’s proper?
1977 Trans Am 400/4speed (swap) Brian |
To fog the entire engine if its in running condition sea foam says to do both, spray down the carb/throttle body with engine running, then after shutting off pull plugs and spray into cylinders then rotate engine a few times to coat cylinder walls. If its not running then spraying in cylinders through plug holes as well as pull a valve cover & spray around valves. Could also just use clean oil in cylinders and rotate engine to spread around... thats how it was done before these fogging sprays were around.
https://seafoamworks.com/knowledge-b...ea-foam-spray/ |
Thank you
Stabile fogging oil
Ive been using stabil fogging oil for years and really like it.
I have fogged my two stroke boat engines for many years. You run it at about 1500 RPMs and fog through the carb or throttle body til it stalls. Thats it!
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
Thanks - I have used Yamaha store it and ran out.
Bought Foggit - cause I liked the NAME - LOL! |
