Old 11-13-2023, 06:32 PM
steve25 steve25 is online now
Are there no instructions with the dye?
  #1862
Old 11-13-2023, 06:59 PM
Sirrotica's Avatar
When using dye you need to, clean the whole bottom of the car, run it right after putting the dye in it, and look at it with the UV light. If left in there for an extended time, the air flow under the car spreads it all over, making it next to impossible to find the source of the leak, speaking from experience.
In my dealings with using dye, there are no ill effects from leaving it in the lubricant. We didn't drain it out after the initial investigation to find the source of a leak. As far as what we used in dealerships, there was no need to drain it.
Mike Garblik says that the smoke machines work much better than dye does, so even though I've never used a smoke machine, I tend to believe him. The dye is less than easy, or foolproof for finding leaks. Sometimes you can clearly see the source, but not always as if you don't use the light at the exact right time, it can give you misleading information as it spreads.
Many times I've just cleaned the bottom of the car, the have someone run the car on the lift, that way there is little air current moving the lubricants around, maybe a little from the fan, but nothing like when the car is running down the road at 55 MPH. No dye, just watching for the leak to show itself by the first drips. Even in a dealership, this was how we identified 99% of the leaks, we seldom used dye.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 2 Users Say Thank You to Sirrotica For This Useful Post:
  #1863
Old 11-15-2023, 05:22 PM
geeteeohguy's Avatar
Where I used to work we had a couple of smoke machines and I swear by them. They will find vacuum leaks, air leaks, oil leaks, anything you can think of and lead you right to the leak. Also, really not messy to use, no clean up. If you can access one, I recommend it highly. I have found some really obscure leaks I never would have found otherwise on multiple vehicles...and in a few minutes instead of hours.
Jeff
The Following 2 Users Say Thank You to geeteeohguy For This Useful Post:
  #1864
Old 11-15-2023, 05:27 PM
64speed's Avatar
64speed 64speed is offline
I have been looking into this but the ones on Amazon are so expensive.
  #1865
Old 11-16-2023, 11:58 AM
grivera's Avatar
grivera grivera is offline
I bought this one last time it was on sale - around $100. I’m sure it or one like it will be on sale Black Friday: AutoLine Pro Automotive Smoke... https://www.amazon.com/dp/B0B2JV8YDP...p_mob_ap_share
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
  #1866
Old 11-16-2023, 12:14 PM
grivera's Avatar
Will Rivera
  #1867
Old 11-16-2023, 12:29 PM
You can save money and simply pour some of this down the intake:
  #1868
Old 11-16-2023, 01:05 PM
JSchmitz's Avatar
JSchmitz JSchmitz is online now
LOLOL!!! Good one!
  #1869
Old 11-16-2023, 02:37 PM
P@blo's Avatar
P@blo P@blo is offline
Originally Posted by JSchmitz View Post
LOLOL!!! Good one!
That’s an old sparky joke. Once you let the circuit smoke out, things seem not to work so well. Had no idea you could buy replacement smoke…
  #1870
Old 11-16-2023, 03:32 PM
JSchmitz's Avatar
I've heard of letting the smoke out of an engine. lol
Wire harness smoke is in the aisle with blinker fluid?
  #1871
Old 11-16-2023, 04:21 PM
64speed's Avatar
Went over my head I guess
  #1872
Old 11-16-2023, 09:45 PM
Sirrotica's Avatar
If you ever worked on a car (Jaguar, Triumph cars, and motorcycles, Austin Healy's, MG's, eic.) or a piece of on site construction equipment, mostly manufactured in the UK, (sometimes also made in Canada too) with a Lucas electrical system on it, and saw the bizzare way that they run current to make a simple DC electrical circuit amazingly complicated, it would be crystal clear what the purpose of bottled Lucas circuit smoke was about in the joke. Lucas engineers seem to be able to make the path of electrons, long and tortorious, with a lot of excess wiring, and are also able to make them tough to troubleshoot, as well as unreliable.
Without having dealt with a Lucas system at some point, you'd have no idea of what the joke was about.
There is another commonly told Lucas joke that has been around for decades. It goes like this, Why do the British drink warm beer? Because they have Lucas refrigerators.............
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #1873
Old 11-16-2023, 10:03 PM
Lucas.
The Prince of Darkness.
Probably one of the biggest reasons British cars never caught on here in the states.
  #1874
Old 11-17-2023, 08:41 AM
66sprint 66sprint is online now
Followed closely behind by Magnetti Marelli wiring.
The Following User Says Thank You to 66sprint For This Useful Post:
  #1875
Old 11-17-2023, 10:22 AM
The old joke I've heard is that Lucas invented intermittent wipers long before they became industry standard.
Old 11-17-2023, 11:37 AM
JSchmitz's Avatar
I had those on a '55 Chevy Sedan Delivery! Vacuum wipers stop when you floor it. PERFECT!
  #1877
Old 11-17-2023, 04:47 PM
Dragncar Dragncar is offline
Not those cars but I have done plenty of work on a Austin Marina back in High School.
Never, never NEVER and British cars for me after that experience.
  #1878
Old 11-18-2023, 06:54 PM
blueghoast's Avatar
Now that is funny, Good one I like.
GT
  #1879
Old 11-19-2023, 03:25 AM
NeighborsComplaint's Avatar
GT
It gets even more comical when you crest the top of the hill with your wipers seemingly frozen in place and let off the gas to coast down the other side as they flap away like a Canadian goose taking off.
Triple Black 1971 GTO
  #1880
Old 11-19-2023, 10:10 AM
I had a '58 Caddy with those vacuum wipers.
