But honestly, I don't remember it smelling this bad in the past so I'll remain optimistic. But then again, it never ran well until Jeff fixed the carb and I got the distributor working right. I haven't used that Marvel stuff since the 70s... thanks for that idea. Mike |
Any carb bought needs the idle mixture adjusted on the engine it is going to be used on.
I suggest adjusting the idle mixture. I can't see how someone else can set the idle mixture before bolt on unless they have the identical engine and timing at idle.
The Following 2 Users Say Thank You to ta man For This Useful Post: | ||
