Old 10-21-2023, 01:36 AM
Verdoro 68's Avatar
Default Lug...bolts?
I was at a car show this afternoon with a '70 El Camino SS parked next to me. When it pulled out, I noticed the rear wheel was held on with hardware store bolts vs. lug nuts. That's a new one to me.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
Old 10-21-2023, 01:49 AM
Many VWs and BMWs use lug bolts instead of studs with lug nuts.
Not sure exactly what’s going on with that SS though but whatever works I guess.
Old 10-21-2023, 02:06 AM
Verdoro 68's Avatar
Our old VW had them. I was just thinking of what it took to make them work on this one.
Ken
Old 10-21-2023, 02:09 AM
It is quite odd to see that El Camino with those lug bolts.
I guess that’s one way to avoid the dreaded ‘spinning stud’ when they lose their press fit into the hub and you can’t get the wheel off.
Old 10-21-2023, 02:20 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
They are grade 5 bolts. And they don’t seem to have the centering cones like german cars.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 10-21-2023, 02:24 AM
Well it looks to have drum brakes. They got it fixed however they thought would work.
Some backyard engineering going on there.
Old 10-21-2023, 02:29 AM
PunchT37's Avatar
Wonder if it’s got a ZZ632 engine in it? Ya’ll wanna go for a ride?
Old 10-21-2023, 08:27 AM
Looks messy at the "washer" area. Reminds me of rims that don't (versus do) center-up on the axle hub.
Old 10-21-2023, 09:12 AM
VWs and Volvos use bolts. Hate 'em. Not so bad on a bug but for an SUV it's a real pain having to lift a heavy tire in place and holding it there while getting a bolt lined up and started.
Been looking for a 4-5 inch bolt to fit my wife's Volvo thread so I can cut the head off of it to thread into one of the holes as a starter lug. That way I just have to hang the wheel off it to get the others aligned and started.
Old 10-21-2023, 09:39 AM
72projectbird's Avatar
72projectbird 72projectbird is online now
My German stuff has bolts. I usually convert them to studs.
I'd like to see that ElCo do a few hard launches with those hardware store bolts. Should be entertaining. I bet they're doing a number on the lug openings on the rims.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 10-21-2023, 09:54 AM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
WOW!! Right up there with compression fittings on brake lines!
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
Old 10-21-2023, 06:09 PM
Dennis H.'s Avatar
Dennis H. Dennis H. is offline
Talk about sketchy! No way in the world would I trust those bolts, if he gets on it, those are going to shear right off.
Old 10-21-2023, 07:42 PM
What they could be are early full size Buick wheel bolts - they are 9/16" in diameter and with the right tap would work fine.
These would have the correct taper if the rims were reamed out to fit . Wheel bolts usually are used with a guide stud to hold the wheel in position.
Old 10-22-2023, 12:36 AM
dataway's Avatar
dataway dataway is offline
Those actually look like Buick wheels to me.
Old 10-22-2023, 06:52 AM
Dennis H.'s Avatar
I enlarged the picture to get a better look, and they definitely look like hardware store bolts with the holes looking mushroomed. Also those look like the correct SS wheels, as Buick wheels were chrome rims and spokes and had no trim rings. Someone spent more time doing this rather than repairing the studs the correct way. Scary being on the same road as this idiot.
Old 10-22-2023, 08:44 AM
The Buick rally spokes don't have a taper like that. I'm sure they're Chevy wheels.
Old 10-22-2023, 09:56 AM
Jonsie Jonsie is offline
Yeah, my brothers '51 Buick has 'em
Old 10-22-2023, 11:15 AM
Those are Chevy wheels. I have the same set in the garage.
1987 Grand National
Old 10-22-2023, 01:26 PM
Yep, YA's or AO's. 14x7 SSI wheels were originally made by Motor Wheel in Lansing MI.
Just like the Cutlass/442 black/chrome LZ coded version
Through the late 80's up into the mid 00's, had a BUNCH of nice ones & passed on MANY more that were damaged from idiots with impacts. Even 25 years ago, ton of the 14x7 SS I wheels exhibited wallowed out (stretched) lug nut holes. Something to examine before buying!
Old 10-22-2023, 05:37 PM
Simple Man's Avatar
You think any of that actually happened with that set up?
be a simple...kinda man.
