Old 06-07-2016, 11:48 AM
67TIGER's Avatar
67TIGER 67TIGER is offline
Question '67 Vacuum Dashpot Adjustment
I have one of these vacuum diaphragm dashpots on my 67 GTO automatic. I can't find anything about how to adjust it.
I think I remember seeing something about getting idle speed and curb idle set then adjust the threaded part of the dashpot until it touches the bracket + 2 turns more(??)
I don't know if that's right or not, it has been a long time. There is nothing I could find in the Pontiac service manual, of course I could have missed it.
Anyone remember how to set this thing?
Thanks!
Name:	67 GTO Vacuum Line Location.jpg
1967 Pontiac GTO
1965 Olds Cutlass
2014 Ford Mustang
GTO-The Great One for 1967
The Following User Says Thank You to 67TIGER For This Useful Post:
Old 09-20-2023, 02:54 PM
Hotrodjohn71 Hotrodjohn71 is offline
Did you ever find information or documentation on that dashpot adjustment?
File Type: jpg Screenshot_20230920_115020_Samsung Internet.jpg (109.6 KB, 39 views)
Old 09-20-2023, 04:04 PM
67drake's Avatar
67drake 67drake is offline
John, I saw your post over on the HAMB. There are a couple carb gurus on this site that might be able to answer the question if you post it here.
I’d start a new thread
13.95 @ 102.1 on street tires @ 4055lbs.
Old 09-20-2023, 08:55 PM
gto4ben gto4ben is offline
The adjustment instructions are in the Pontiac Chassis Service manual. 64,65,66, & 67 manuals all target ~1050 RPM [(1030 to 1080RPM) after the Throttle Return Check (dashpot) vacuum hose is disconnected and plugged with the engine warmed up..
Check if the dash pot holds a vaccum The diaphrams do tear and will leak due to its age and wear. The 67 quadrajet version is unique due to the bracket and is not serviceable; however, you can get them functional by substituting a diaphram from the still available 2 barrel or carter 4 barrel if you modify the rolled edge to screw together. A 1-72 thread works well.
Name:	67 throttle return check adjustment.jpg
ID:	620277   Click image for larger version
ID:	620278   Click image for larger version
ID:	620279   Click image for larger version
The Following User Says Thank You to gto4ben For This Useful Post:
Old 09-20-2023, 10:27 PM
Thanks a million. I greatly appreciate it.
