Old 08-26-2023, 06:02 PM
64speed's Avatar
64speed 64speed is online now
First showing got me a 10 dollar gift card for a local Mexican Restaurant.
  #1802
Old 08-26-2023, 06:42 PM
Gach's Avatar
Gach Gach is offline
Nice !! And well deserved.
  #1803
Old 08-26-2023, 07:08 PM
64speed's Avatar
It wasn’t even clean lol
The Following User Says Thank You to 64speed For This Useful Post:
  #1804
Old 08-26-2023, 08:24 PM
Gach's Avatar
So now you’re a burrito man…LOL
  #1805
Old 08-26-2023, 11:39 PM
Bill Hanlon's Avatar
Maybe 5,000 more showings and you'll break even.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
  #1806
Old 08-27-2023, 01:59 PM
64speed's Avatar
Next step is carpet. Will the jute backing help the heat any or does there need to be something between it and the sound deadener?
  #1807
Old 08-27-2023, 03:04 PM
The OE jute stuff is marginal, at best. The dynaliner or stuff like it is the way to go. I do a mix of 1/4" and 1/8" thickness in diff areas, depending on where it is, so the carpet will lay properly.
I may have used some 1/2 too, but honestly would have to go back and look.
I did both the 442 and the GTO with a combo of dynamat and dynaliner, and it is such a dramatic difference, I will always do it from here out.
I stripped the jute off the back of the carpet before installing over the dynaliner so it would lay right.
  #1808
Old 08-27-2023, 07:58 PM
gtospieg gtospieg is offline
I've read good reviews about Lizard Skin...2 part system for sound and heat.
  #1809
Old 08-28-2023, 10:53 AM
Lizard Skin is good stuff, nice you can spray it, but not everyone can do that in their' garage. Have to be careful not to build it up in areas too.
After Dynamat started getting popular, a ton of companies joined the market, and quality was all over the place. I've used Dynamat for a while, so just stuck with it. Sure there's plenty of stuff out there that works fine, I just haven't gone back to do the homework/comparisons.
  #1810
Old 08-29-2023, 09:05 AM
64speed's Avatar
I am gonna install my own door panels because I got an estimate yesterday and they want 250 per panel. Not paying that. I watched some videos and other than cutting for the window switches it’s not rocket science. How much are you guys paying for headliner install. I have it and all the bows are in order. Upholstery shop said 1500. Not gonna try it but seems steep to me
  #1811
Old 08-29-2023, 09:25 AM
At this point this should be moved by a moderator out of this section.
This string is crazy long as it is now!!
  #1812
Old 08-29-2023, 10:17 AM
64speed's Avatar
Plenty of build threads in this section.
  #1813
Old 08-29-2023, 10:47 AM
Door panels are cake. Bow headliners, not so much of a cake.
1500 is insanity. For that, you can do it 3 times yourself, by the 3rd, you will have it perfect.
  #1814
Old 08-30-2023, 08:26 AM
tstroud tstroud is offline
I was really worried about doing the bow headliner in my car. I finally just went ahead and did it. It took the whole afternoon to do it and it turned out pretty good with only 1 small wrinkle in the left rear corner. That seems to be shrinking in as time goes on. If it doesn’t go away I will adjust it. I’m glad I didn’t pay someone a small fortune to install it and probably still have the same little wrinkle.
It’s not really that hard. Work from the dome light forward, them work from the dome light back. Put all the screws in place before starting so you can find them later to cut them in.
Get good glue. I used the 3m spray glue and it’s not holding very well. DAP weldwood seems better. I should have used that.
Sent from my iPad using Tapatalk Pro
  #1815
Old 08-30-2023, 09:06 AM
Yeah, you start from the fixed position bow, work forward, then from the fixed bow back.
You can use a hair dryer or heat gun after it's in place to help it relax, just be careful if you use a heat gun.
I used the 3M 90 spray glue, it works fine. I tried some of the brush on stuff and it was terrible.
For the spray, I used pieces of cardboard as a back stop when spraying, cardboard from canned 12 pack drinks works well, cut up like 20 pieces and after one or two spray pick up another piece.
I bent the tack strip points out a little, and some hit the points with a file so they grabbed better. That helps a lot.
  #1816
Old 08-30-2023, 09:09 AM
Mark the holes the bows are in with a sharpie before you remove them. It helps, but depending on how the headliner is sewn, you may have to change them anyway.
It's much easier if you do the headliner before you put the glass in, but can still be done with the glass in.
  #1817
Old 08-30-2023, 09:19 AM
Couple in-progress shots as an example.
I trimmed an area too short around the back window and then gave up, just got it up there knowing I would have to do it again. Uhg. Just part of the process.
One pet peeve I have is along the side where the headliner slopes is when people cut the bow pockets too far and make 'circus tent' puckers on the sides. Big no-no in my book, even if many factory jobs look that way.
I try to get it as tight to the roof as possible, give as much headroom as possible.
Next summer I will redo the judge one, I have the 'bird coming back from paint in a couple weeks, that will be my winter project.
ID:	619079   Click image for larger version
ID:	619080   Click image for larger version
  #1818
Old 09-02-2023, 02:17 PM
64speed's Avatar
Drove to a car show last night and as I was pulling in the sharp left hand turn made a terrible scrubbing noise but after thorough inspection I can’t find it and it doesn’t do it consistently so I don’t know
  #1819
Old 09-02-2023, 03:28 PM
How about one of your front tires is rubbing on or near the roof of the wheel well when turned to enough of a extreme?
This condition can come and go depending on if the front suspension is being compressed as when coming up out of a dip in the road or into a transision in the road suface.
  #1820
Old 09-02-2023, 04:12 PM
On 1964 & 1965 cars the rear bottom of the wheel opening has a point at the bottom corner of the opening that often rubs on the tire when you’re running wide wheels. This only happens on tight slow turns.
I was running zero offset (4.5” backspace) 17x8s with 235/45-17s on my ‘64 Tempest and had to tap that point in with a hammer to stop the rubbing. It didn’t take much because my tires were only 25.3” tall, anything taller will require more clearance work.
