Old 07-28-2023, 05:53 AM
3X24SPD 3X24SPD is offline
One more- PB, PCV, VA provisions.
I also ground that ugly ass "Tradewind" & "Kauffman" embossing off the front runners.
I left the three "Made in USA"- but in retrospect I should have disappeared the two on the sides as well.
I'm very supportive of Made in USA- but the one cast on top is sufficient for me.
1966 GTO (Red) WARPATH
455CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
464CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
Old 07-28-2023, 05:56 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Very cool new part!
Old 07-28-2023, 08:23 AM
Gary H's Avatar
Gary H Gary H is offline
Be nice if they made a 2-4 top,lots of hood room.Tom
KRE had a dual 4 bbl top at Norwalk that bolts on the manifold. Don't know if it's available to the public yet though.
Old 07-28-2023, 08:31 AM
Gary H's Avatar
Originally Posted by Dick Boneske View Post
Would be interesting to see a HP comparison between the Holley two barrels vs. real Tri-Power Rochester Carbs.
The stock end carbs flow very well, and the center carb would be better by far for MPG on the street. Anyone who has used Holley carbs on the street knows they use a lot more fuel than many other carbs.
I spoke with Jeff Kauffman at Norwalk and they had just dyno'd a 535" that morning and compared the two intakes set up's. The engine was a 535" that had out of the box High Port heads and pretty mild hyd. roller cam. The original style intake was aluminum repop that had been cleaned up and used original carbs. The KRE intake was used with 3 Holley 2 bbl's with no jet changes. The difference between the two was 80 horsepower with the new intake peaking at 680 hp. Pretty impressive increase!
Old 07-28-2023, 10:14 AM
Very Nice Increase in power with the Holley 2-BBL carbs on the KRE Intake.
I had Dave Wilcox port a Barry Grant Pontiac aluminum Tri-Power intake and saw a 50 hp increase on a 462 engine with Holley 500 cfm Carbs.
No surprises on the post above. Thanks Dave W (years ago).
Old 08-24-2023, 05:59 PM
mike w mike w is offline
See new post comparing set of Holleys and Rochesters on the new KRE tripower intake.
Old 08-24-2023, 09:55 PM
Dick Boneske's Avatar
Where is the post comparing Holley Rochester carbs on the new intake?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 08-24-2023, 10:53 PM
Whereis the post comparing Holley Rochester carbs on the new intake?
Link to post:
https://forums.maxperformanceinc.com...d.php?t=868796
