Old 06-23-2023, 06:41 AM
pontiacmark's Avatar
pontiacmark pontiacmark is offline
Question Clutch and pressure plate recommendation?
Just finished the rebuild of a stock 400 to a built 461 stroker. Figure about 425 hp and 500 lbf-ft. When the trans was installed, a stock replacement Sachs clutch and pressure plate were installed. I don’t have confidence in the longevity of this clutch even though it has very few miles on it. The car is just going to be used as a fun street car and I don’t have plans to take it to the track. So, does anyone have a recommendation of a budget friendly, won’t wear out my left leg, street clutch/ pressure plate combo? Not looking to upgrade to hydraulic at this time.
1970 GTO 400 Atoll Blue, PS, PDB, A/C
Was M20 4 speed, now has Keisler RS600 5 speed.
Old 06-23-2023, 07:31 AM
chuckies76ta's Avatar
Stay with an organic clutch.. ACT, Mcleod, CenterForce., Spec, Ram, Hayes. Lots of manufactures out there. Lots of post on P/Y also. For safety you could also look into a SFI approved clutch. Billet steel flywheel and a SFI approved bell housing. Expensive yes but so are your legs if anything happens. I like the Quicktime bell housings.
Old 06-23-2023, 10:44 AM
tom s tom s is offline
Have had great luck with McLeod,have them in all 3 of my cars.Tom
The Following 3 Users Say Thank You to tom s For This Useful Post:
Old 06-23-2023, 10:51 AM
https://www.summitracing.com/parts/mcl-75221
Looks reasonable.
Old 06-23-2023, 11:02 AM
jhein's Avatar
jhein jhein is offline
Originally Posted by pontiacmark View Post
I have the Mcleod 75321 one step up from the 75221 for more power capability. I have a the stock Z-bar system. I like the pedal feel. Not hard at all. Seems to handle my power level well. The 75221 should be perfect for you, and it's still sfi rated.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 06-23-2023, 11:14 AM
bhill86's Avatar
bhill86 bhill86 is offline
I have probably 100hp less than you in my setup but I run a LUK. Easy on the wallet and my left leg.
1977 Trans Am 400/4speed (swap)
Brian
Old 06-23-2023, 02:47 PM
I also run a LUK. Very happy with that companies' Clutch and Pressure Plates.
